Question about Frigidaire FRT21H7AS Top Freezer Refrigerator
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
I have a Frigidaire top freezer bottom refridgerator model FRT21H7AS that I need some advice on. This weekend we found that the food in the freezer had all thawed out and the freezer is no longer working but blowing hot air while the fridge was still cooling, but as a few days have passed even it is slowly going away and barely cool at all. I opened the back access panel and cleaned to make sure it was getting air flow and that the fan was working which it is. The compressor tries to kick on and will run for about 5-10 seconds before it clicks off. And it does sound a little rough when it tries to kick on. Does this sound like a compressor gone bad or am I missing something? What sucks is the 5 year factory warranty just expired about 2 weeks ago. Any help or advice would be great. Thanks.
  • soprano2125 May 18, 2009
    Do you think if I replace the relay that I should replace the capacitor as well or do most problems come from the relay?
    President:
  • 1,136 Answers
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
Posted on May 18, 2009
  • Victor
    Victor May 19, 2009
    I would replace them both. It would cost around $47.00
My top freezer is not cooling, but the refridgerator section is cooling. Refridgerator makes a clicking noise. What could be causing this? I have a Whirlpool 21.0 cu.ft with icemaker
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Frigidaire FRT21H7AS freezer is not working properly. It will freeze ice, but the ice is slick and some of the food is thawing. The fridge part is fine. I haven't noticed any temp problems with it. Just...
first try manual defrost/ cleaning drain holes,possibly blocked.no hot water.dry out, then switch back on should be okay.if not try replacing temp sensor in freezer.before you do use freezer temp guage to check minus 20c
Feb 11, 2010 | Frigidaire FRT21H7AS Top Freezer...
My Amana ARB9059CS refridgerator is not cooling. Fans blowing top and bottom. Makes a clicking noise every few minutes. Tried unplugging it for a day, then plugging back in. Did not help.
The clicking noise you hear is a relay trying to start your compressor but your compressor does not want to obey! Compressor most likely is bad and needs to be replaced or all your refrigerant gas has leaked out and would need to be repaired and system re-charger with refrigerant gas. Not a cheap venture either way. Might want to consider getting a new one.
Nov 07, 2009 | Amana ARB9059CS Bottom Freezer...
FRIGIDAIRE: THE TOP FREEZER WORKS GOOD BUT THE REFRIDGERATOR SECTION WILL ONLY COOL DOWN TO 49 DEGREES
Most likely the defrost timer part number click here=> 215846602 located inside the fresh food compartment is defective. Below is a photo location number 23 is the timer. There should be a small opening below the control panel with a plastic plug covering the hole. Pry the plug away and with a flathead screwdriver turn slowly colckwise until the compressor stops. The compressor shouls remain off for about 25 minunites and during that time the freezer should be in defrost. Open the freezer door and listen for sounds of sizzling or crackling. If nothing happens then the defrost time may be the most likely part to replace. If compressor does not restart after that time simply turn the timer again slowly until it restarts. If you should need parts or review photos of your model click here=> Point and Click Appliance Repair and simply enter your model number or part number into the model and search feature. If this has been helpful please let me know, Thanks, Sea Breeze
SEA BREEZE TIP'S
Oct 28, 2009 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Refridgerator won't cool, freezer is OK
if it is a bottom freezer and top refrigerator it is low gas in the system need to be topped up
May 12, 2009 | Samsung Refrigerators
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Making lots of noise when running help? please kenmore refridgerator model 25368821790
Hi
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Frigidaire FRT21H7AS Top Freezer Refrigerator Logo
325 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
