Question about Pioneer Vsx-522-k A/V Receiver
Can't get the video on tv when hooking up wii to the rca jacks on a Pioneer-VSX-522-K-5.1
The receiver is working. im doing this for a friend.the receiver has rca's for left and rite audio dvd and separate rca for video dvd. when I put it on dvd I get sound but no video .I what to hook every thing to the receiver so he can switch sources though it. what did I miss .
techman
  • 3130 Answers
SOURCE: Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Posted on Jul 30, 2007
  • 14 Answers
SOURCE: Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Posted on Apr 02, 2008
petraman7
  • 1175 Answers
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Posted on Feb 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
one5oneproof
SOURCE: Pioneer VSX-822-k Subwoofer problem
I had the same problem. Dont know why the receiver set it up this way but grab your remote, go down to the lower right and select ch setup. Keep on pressing it till your receiver says SW. Then press lev+ on your remote to change the db on your powered sub.
Posted on Oct 31, 2012
How do I hook up pioneer stereo receiver VSX-D704S to laptop
Use a headphone jack to rca adapter. Plug headphone into laptop headphone jack and connect rca ends to whichever input you want to use on the pioneer.
Oct 08, 2016 | Pioneer Audio Players & Recorders
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Need to hook up to keenwood powered subwolfer 1050sw and im a girl and dont know how
The receiver has a subwoofer out jack on the back. The powered sub has a LF input jack on the back. Connect the two with an audio cable that has 'RCA' plugs on both ends.
Mar 19, 2010 | Pioneer VSX-D409
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
Im trying to hook my pioneer vsx-d409 multi channel receiver to work with my new3 philips hdtv. it would not work please help
What isn't it doing - audio, video, both? What model is the TV. How are you trying to do it. Do you have the manual? The simplest hookup is to just have the a single RCA cable from "TO TV Monitor" to a Video In on the TV. Modifications may be required depending on what else you have for video sources and how they're attached.
Go here for it. Register and search for things, like vsx-d409...
http://www.retrevo.com
Feb 02, 2009 | Pioneer VSX-D409
Receiver to tv hook-up
Is this a Pioneer receiver? They have the prefix of VSX but I can not locate that model on Pioneers website. It could be because it is an older model and no service information is on the website for receivers older than about 5 years old.
To answer your question I need more information. Do you want to connect the video switching of the receiver to the TV or just want the sound of the TV to go to the receiver? I would also need to know what type of video devices you want to connect and what type of inputs and outputs your TV has.
Most TV's have at least a composite video input, that is the most common type. it is a yellow RCA jack on the back of the TV and will be listed as an "input". That is what would be connected to the video output jack (yellow RCA) of the receiver from the TV for video switching. Then you need video sources connected to the video inputs of the receiver to go to the TV. You also need to connect the audio RCA cables from the video devices to the receiver on the proper video inputs that you have connected. Each video input for composite or S-video has audio RCA jacks (red and white) inputs so you can hear the sound of your video device on the receiver.
If you only want to play the sound from your TV on the recevier, you can use the audio output RCA jacks on the TV and connect them to an audio input of the receiver. This is a very simple way of using the receiver for all the different devices connected to the TV without having to connect everything to the receiver and then always having to have the receiver on any time you watch TV. The audio RCA jacks are always the red and white jacks. you just need to make sure you are using the output jacks of the TV and they are connected to an input jack on the receiver. Then you must switch the receiver to what ever input you just connected the TV to, like the "Video 1" or "Video 2" or maybe "Aux" input.
I hope this helps, but you didn't give much information on how you wanted to connect them.
A good rating would be appreciated if you found this free information helpful.
Let me know if you need any more help,
Dave
Jul 06, 2008 | Audio Players & Recorders
HELP! hooking up my components to eachother
Youll need to But a Rf Modulator that Converts Composite Video to Rf Using Channels 3-4 VHF Radio Shack Stocks it Any other Questions let me Know
Jul 19, 2007 | Pioneer VSX-406 Receiver
Pioneer Vsx-522-k A/V Receiver Logo
29 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
