Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Kitchenaid ice maker model KUIC18PNTS1
Not making very much ice. Water dispensing fine into reservoir, pump is circulating but very little ice is being dropped.
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: Kitchenaid stand alone ice maker.
Check and see if your cutting grid is still lined up on the back side towards the freezer plate. I have had the cutter miss align on some and failed to see it then just have to remove the thumb screws and re set the back end. Feel for more roughness from scale. Especially on the sides and edges. you may need to clean it again
This unit I believe is set to allow water in when it goes through a harvest. it wont refill until the coldest temp is reached then will stop filling after the warmest temp is reached.
Posted on Mar 12, 2009
SOURCE: Kitchenaid under counter ice maker:
Kitchen Aid Ice maker is a piece of junk. Best to fix it is to get rid of it and tell friends not to buy it.
Posted on Aug 06, 2010
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker kitchen aid kuic18nnts won't pump water over chill plate. Replaced circulating pump still no water.
Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address kidlmo@gmail.com...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 21, 2014 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
I have a kitchenaid kuic18nnts1 ice maker. It only partially fills the water reservoir causing the pump to run the reservoir dry as the ice is formed on the plate. I have replaced the water level sensor...
Hi hhsawin ,
Have you already check to see any ice blockage in the fill spout tube, this is the hose that caries the water into the freezer section and to the icemaker. If the elbow & tube has a ice blockage, it is usually best to replace the fill valve and the shut off valve. You can try to thaw it using use a turkey baster to spray hot water into the tube.Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Please remember your safety in doing checking and repair.
Hope it helps.
Thank you for using FixYa.
May 10, 2011 | Refrigerators
My ice maker has stopped making ice. I have Kitchenaid Architect II KSRS25FTBL.Water dispenser is working fine. Ice maker is turned on.
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Feb 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
No water inflow into ice machine after turning off ice maker -
Hi, sounds sticky to me, or it wants the kids back home. But anyway try finding the travel of the tube, could have fallen off on other side, or has blockage since we have so much junk in our water today. Also although your filter is green if its good, I would take it out and clean it, not replace just clean it, and a must fine hose must be a problem, wish I was there ! Frankie!
May 07, 2017 | KitchenAid Superba Architect KSCS25INSS...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
97 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
