Question about ROOTS CREAMSICLE Ry2123BLK Watch for Women
Need roots creamsicle instructions
Instructions manual
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How do I set time on roots r316
Have a jeweler do it. Or look for a manual on Google.
Dec 25, 2014 | ROOTS Watches
How do i set my digital watch,roots ry2129
Here is an actual 'live' web link (I just checked) - to Roots, "watches":
http://usa.roots.com/on/demandware.store/Sites-RootsUS-Site/default/Search-Show?q=watches&simplesearch=
If nothing else, if you scroll to the bottom their contact info appears which I am also pasting below. Good luck to you!
Contact Us:
• 1-800-208-0521
• Outside of Canada: 1-972-265-4120
• Email: onlineservice@roots.com
Nov 09, 2014 | Watches
How do I set the date on my Roots MAI TAI RY2142 Watch for Women?
Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now, now press and release the mode button and enter the time setting mode, the seconds will be flashing. Now press and release the start/stop button (top right) and the minutes will flash, again for hours, again for the month, and again for the date. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. Worked for me, hope it does for you too. Most of the other setting changes are tricky as well, just ask for help again if you want to change the alarm or 12 or 24 hour clock etc....
Jan 03, 2013 | ROOTS MAI TAI Ry2142BLK Watch
I need an instruction manual for a timex timt5k575f5 gps watch
Checkout the available manuals from the link below.
www.timex.ca/en/manuals.aspx
Hope this helps.Thanks!
Jan 04, 2012 | Timex Triathlon Watches
Need instruction manual
can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Jul 20, 2010 | Timex Sports Ironman Triathlon 50-Lap...
Instruction manual for invicta elite 9225 need help with the dials and need to know how to use it
Their web site gives a list of generic instructions which you need to
scroll through to find the section that suits your watch.
You can get an instruction manual by going to their web site
(www.invictawatch.com/), put your cursor over "collections" in the
menu across the top and then clicking on "instruction manual".
Click on the link below the "Invicta" logo and download the instructions.
May 21, 2010 | Invicta ELITE 9225 Wrist Watch
I need to know how to use my cl1112 Tag Heuer
Copy "ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf"" into your search engine and it will take you to a generic instruction manual for TAG watches.
This manual includes instructions for operation of your watch.
Mar 01, 2010 | Watches
How do you set the time on the Roots Womens's Mai
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Feb 05, 2010 | Watches
ROOTS CREAMSICLE Ry2123BLK Watch for Women Logo
37 people viewed this question
Top ROOTS Watches Experts
Ansel Alberto
Ansel Alberto
Are you a ROOTS Watch Expert? Answer questions, earn points and help others
