Question about Replacement Parts Industries Lock Screw for Ritter
Instruction manual to dismantle a superleague diplomat pool table
How to dismantle a pool table
Susanna, if this is an 8' professional type pool table with a slate top, you're going to need 2 men and a boy to help you. 90% of the dismantling of parts is done from under the table. Literally, just about everything ( Rails, side panels, legs, etc ) unbolts from underneath. About the only thing that doesn't is the slate top. It may be in two pieces rather than one and it's heavy.
Once you start looking around under the table, you'll see how it all goes together. Except, you'll be taking it apart.
Good luck and hope this helps you dismantle it, safely.
Apr 21, 2011 | Heating & Cooling
Instruction book for Diplomat ADP5426 cooker
I need a manual for a diplomat adp5426 dont no how to work it .it was left with the house
Feb 13, 2011 | Microwave Ovens
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Replacement Parts Industries Lock Screw for Ritter Logo
617 people viewed this question
Top Replacement Parts Industries Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Makenzie Floyd
Level 1 Expert
Are you a Replacement Parts Industries Rock and Ice Climbing Expert? Answer questions, earn points and help others
