Question about Sharp R-120D Microwave Oven
Oven turns off
I have a Sharp R-120D 600 Watts Microwave the clock display and timer seem to be working fine but when I hit start it turns off or rather the electric outlet on the wall which has a safety feature resets or , could this be a blown fuse ??
  • Sharp Master
  • 9,086 Answers
That's usually a shorted high-voltage capacitor or there's a problem with a door switch or door switch mount.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
The digital display no longer works on my sharp half pint microwave r120d. How can I fix this? thanks in advance.
On this model, it's usually not economical to repair, but in most cases it can be repaired for $39.95. Details are here.
Aug 16, 2011 | Sharp R-120D Microwave Oven
I have a sharp carousel microwave model r-120D. It is flashing all 8's like so 88:88 and i cant get it to reset or work at all. Can you help?
usually does this after power outage. reset the clock. go to sharpusa.com and select PRODUCT DOWNLOADS under the CUSTOMER SUPPORT menu...select product not listed in drop down list, then enter R120PK in box....this should be the manual for your microwave
Dec 10, 2010 | Sharp R-120D Microwave Oven
Re. Viking DMOS200 1100 watts microwave oven does not turn on
I'm guessing that's a VMOS200?
If so, that's a rebranded Sharp R-530ES (as is the Dacor DMO2420S) and its secondary interlock (bottom door switch) or that switch's mount is bad.
See this file on door switches. If you only need a switch, you can order a universal type here for $5 postpaid.
The Sharp R-530E service manual will aid you in disassembly and it is here.
Jul 02, 2010 | Viking DMOS200 1100 Watts Microwave Oven
Hums, does not heat when started. Display, timer,
The problem could be the high voltage fuse or the magnatron assembly. replace both to be safe. good luck.
Nov 12, 2009 | Sharp R-1610 Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave light and timer work, but no cooking
IF IT TURNS ON AND SOUNDS LIKE ITS COOKING IT IS PROBABLY THE HEART OF THE MICROWAVE THE RADIATION PART WENT OUT IT IS MORE RECOMENDABLE TO REPLACE THE WHOLE MOCROWAVE
Oct 03, 2008 | GE JVM1850 1000 Watts Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Clock on Microwave
Normally on a Sharp, one of these key combinations will do it:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Let us know if this does not work.
Aug 06, 2008 | Sharp R-254 Microwave Oven
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Sharp R-120D Microwave Oven Logo
82 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
