Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher it cleans poorly - KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
  • semicolon1 May 22, 2009
    My Kitchen Aid KUD101FL doesn't really clean my dishes. I've cleaned out all of the water-bearing parts, run a vinegar cycle, rinsed my dishes, etc. Nothing seems to work. Worst part: I had my motor replaced 18 months ago.
  • KitchenAid Master
  • 43,501 Answers
Not cleaning the dshes. Material lrft on dishes. Suspect poor water flow.
Fill with salt. Clean out all rotary arms. And put a dishwasher cleaner through. The rotary arms get blocked with lime scale.
Sep 16, 2012 | KitchenAid 24 in. KUDM25SH Built-in...
The top is not cleaning and the bottom is cleaning poorly
The most likely reason you are experiencing poor washing results with your dishwasher is because the filter on the pump is clogged. This tip i wrote will help ya to take apart the pump and clean that fliter, http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher won't clean the dishes properly - very poor cleaning results with residue left on the dishes.
Check The Salt-Level ? Dishwashers rely, On salt and cleaning Fluids/Rinse Aids et,c. Also check for Any Blockages or Obstructions/Kinks/Bends et,c. in The External Outlet/Waste pipe.
Mike.
Jun 02, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Poor cleaning
Check inlet water pressure. Clean the strainer attached to the machine body!
If every thing is OK check the pump.
May 20, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
I have a Whirlpool GU2600XTPS7 dishwasher - long washing time
You could have a couple things going on here. It could be either related to water temperature, build up in the sensor area or poor washing.
If the dishes are coming clean then you can discount the poor washing.
1st thing to try is clean out the dishwasher, a build up or residue can form on the sensors in the bottom and they can be fooled into thinking the water is cloudier or cooler than normal and it would take longer to heat the water and wash. Here is a link to some instructions I put together on how to clean it out.
Clean Out Procedures
2nd thing to try would be to run the hot water in the kitchen sink until it is hot before you start the dishwasher. By doing this the dishwasher will not have to slow down and pause while it is heating the water enough to clean the dishes
May 01, 2010 | Dishwashers
Dishwasher no longer clean dishes as well as it use to
Hello there
There are several reasons why a dishwasher will start performing poorly and dishes are not getting cleaned here is a list of things to check
It cleans poorly If your dishwasher is cleaning poorly, check these: things that i have listed below by clicking on each one and it will give a description ok? Water-inlet valve Internal filters Drain valve Spray arms Water temperature Detergent cup
I
Apr 02, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Gritty film left on almost all dishes, rinse aid level seems to always remain at full, but apparently not rinsing well.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Mar 11, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Poor Cleaning and getting worse
A common cause of poor washing is improper loading—dishes block or impede the spray arms or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with washing, the problem may not be your dishwasher. Your home's water pressure may be too low, the water may be too hard, you may not be using the right amount of detergent, or the water temperature may not be hot enough
Apr 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Doesn't clean dishes completely, especially the top rack. also it doesn't completely empty out the detergent dispenser.
To the people here with the poor cleaning problems:
Try these steps:
Buy a small box of Cascade or Electrosol diswashing powder. Use only it for 30 days and report back. Do not use gel, tablets or ultra low end detergent. I have proven that ultra cheap powder WILL cause problems.
Also, fill a bowl or large cup with white vinigar, place it in the bottom shelf of of the empty dishwasher. Do not add any detergant. Run a normal or quick cycle.
If you still have poor cleaning, it is time to call for service or remove the filter beneath the lower rack and search for debris that will need to be removed.
Please report back with your results and the make/model of the dishwasher. Good Luck!
Dec 22, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
291 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
