Topaire air conditioner Timer mode problems - Heating & Cooling
3 Suggested Answers
  • 11 Answers
SOURCE: air conditioner not working
unplug it for few minutes and then restart it. This shold reset the timer.
Posted on Jul 08, 2008
hvac1960
  • 2133 Answers
SOURCE: how to clear timer mode on air conditioner
Very simple. Remove batteries from remote and after sometimes replace batteries and use the remote.
One more method, press timer button and then press < or > till it comes to 00.00. And then press set button.
Another method, press timer on and then press cancel button. Hope, helpful?
Posted on Feb 11, 2011
Sharp AF-S100FX Comfort Touch Air Conditioner not working
You may have it in a timed mode. Here are the instructions for your unit. There will be a start delay if it is in timed mode. My Retrevo My Manuals
May 15, 2014 | Sharp Comfort Touch AF-R120EX Air...
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Panasonic air conditioner with seral nr. A75C2616
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Jul 15, 2013 | Heating & Cooling
How to clear timer mode on air conditioner
Feb 11, 2011 | Fujitsu 36CS Air Conditioner
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Set time on KA25
Hello Try taking the batteries out for 15 min and start over.Timer mode is a sleep setting.
Mar 31, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Air conditioner not working
Jul 07, 2008 | Fujitsu Heating & Cooling
Fijutsui air conditoner
We had a similar problem. The timer light would blink 3 times, pause, then blink 3 times again, pause, and so on. The fan was blowing lots of air out, but the air was not cold. The operation light was off.
The technician came and fixed it for free, since it's actually easy to fix. He went to our circuit-breaker box, and cut power (from the box) to the air conditioners for 30 seconds. Then, he restored power - problem fixed!
It's apparently because the air con goes into a "safety" mode when there's a power surge.
Jul 06, 2008 | Heating & Cooling
Problem with RAS-30CS5
the system may not have any refrigerant in it, this may be a safty cut out. hope this helps
Nov 21, 2006 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
294 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
