I have a HP officejet 4200 Series all-in-one printer. It continually tells me that I have a paper jam. I do not have this. The printer will copy, but will not print from my computer. Please advise.
  • keppt May 19, 2009
    Sorry this did not work - wish it had.
    Have tried turning off the printer and restarting it - that did not work either! Thanks anyway!
    Problem Solver:
  • 12 Answers
Look inside there may be a stray peice of paper triggering a sensor that brings up the paper jam message
Posted on May 18, 2009
Have a false paper jam on my HP all-in-one J6400 series printer
look here
http://h30434.www3.hp.com/t5/Other-Printing-Questions/HP-OfficeJet-J6480-false-paper-jam-error/td-p/12759
Apr 04, 2014 | HP Officejet J6400 series
My all in one printer continues to feed paper and says it is jammed.
I would replace the printer. The reason? Printers are so cheap for home systems that repairing it cost more than just replacing it. Canon (and others) makes an excellent all in one series with prices for everyone's pocket book needs. I have bought my 1st Canon and like it much better than my previous 3 HP printers for quality of product and ease of use.
Jul 12, 2012 | HP Officejet 6310 All-In-One InkJet...
Printer continuously says there is a paper jam, but no paper jam exists. I have run paper through several times and it still says paper jam. How do i clear this? Kirk
Turn off the printer
Remove the Rear Access door
Clean the collers ( upwards ) with lint free cloth.
Close the Door.
Scuffle the papers in tray and place them
Try to make copy or print.
Feb 07, 2011 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Reinstalling HP 4200 series printer and has x on administrator
An X against Administrator Rights when I try and reinstall an HP printer
Oct 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
277 people viewed this question
jasbo
jasbo
