Question about Refrigerators
PS123SGRD refrigerator water dispenser stopped
SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
Posted on Sep 15, 2007
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
the dr
  • 447 Answers
SOURCE: water dispenser won't work
see my posts in my solved solutions on water line freezing. I can email you a bulletin for a heater kit.
Posted on Dec 06, 2007
Sea Breeze
  • 4654 Answers
SOURCE: My Maytag side by side refrigerator's water dispenser won't stop
Below is a picture of the fountain parts. I believe the controls inside the fountain are defective and will need replaced. Temporarily disconnect the control valve to the Fountain control plug this will allow the ice maker to continue to work. Let me know if you need more help and assistance to solve this problem. Below is a link to my site, email and a photo of the parts. Thank You, Sea Breeze appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Posted on May 31, 2009
  • 13 Answers
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Posted on Mar 21, 2010
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
The water from the dispenser is running and i can't stop it how do you turn of???
The cause of the problem you describe could be ether water inlet valve or the water lever dispenser switch.Locate the water valve at the back of the refrigerator, open the water and take off both plugs from the valve. If the water flow want stop replace the water valve. If it will, replace the water lever switch.
Mar 24, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser will sometimes drip and doesn't stop. It doesn't stop by pulling forward on the lever, I have to push it in as though I'm dispensing more water and that usually stops it. If I don't...
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Apr 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Water dispenser stopped working.
if your ice maker works fine then its going to be your solinoid valve thats bad oin the dispenser.
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Profile Refrigerator water dispenser stop working...
This could be a bad water valve on the back of refrigerator or the dispenser is not asking the water valve to open. There are 2 valves in back, one is for ice maker and other is for the dispenser. I will help to try to locate the problem if you need, let me know, Thanks, Sea Breeze
Mar 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
