Question about Galaxy Radios DX-979 40-Channels Base CB Radio
Radio will not come on. it burnt something near the power wires. where they come into the radio. whats wrong with it?
Cant see anything burnt, but i can smell it.
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Reverse polarity diode burnt out
Posted on Aug 09, 2014
2 Suggested Answers
steve132003
  • 98 Answers
SOURCE: Power wires shorted out. something
You probably burnt resistors,relays and transistors near front end sections. Need to take to shop or do yourself. Small solder pencil, solder ******, and change all parts and tiny relay box which may be a black square(but,it rarely fails) I would say transistors,capacitors,resistors. Best to let professionals have a look..Cb shops,Radio Shack, www.copperelectronics.com. Galaxy Radio.Inc.People who service radios; they may charge a good price $$$ though. About $18 to $30/Hr. Labor plus parts.
Posted on Apr 08, 2011
Power supply connected wrong way
go to www.cbtricks.com they have a service manual for this radio. Check all the 1n4801 diodes for one that is or looks burnt. especially one near the power connector.If you find a burnt one replace it.
Feb 16, 2014 | Radio Shack TRC-447 CB Radio
My cobra 29 classic wont turn on
polarity protection diode near power input burnt.
Apr 14, 2013 | Cobra 29 LTD CB Radio
Power wires shorted out. something smoked near the mic connector. The radio does still power up and recieve. It will key up if I cross the mic pins. checked the mic on another radio thinking it could have...
Mar 27, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
We hooked up the cb radio and the meter light lit up.... my buddy tiltted the radio back and it started to smoke, i took the cap off and the smoke was comming from under the echo board, we fixed one...
If there was a direct short to ground.....which it sounds like there was....it would've blown the protecton diode. The protectio diode is located near the power plug on the inside of the radio (component side). It will be black with a white stripe at one end, It looks like a little can/cylinder with wires coming out of each end. Kinda like a resistor.....but smooth.
The problem lies HERE.....
If it did burn the diode, it will not look like that, It will be a crispy little black thing that falls apart when you touch it.
Just look around near the power plug for a burnt component. If you see one...well...thats probably it.
FYI: the diode will be directly between the pos and neg leads in the circuit near the plug.
Also...CHECK THE FUSE!!!!
One more thing. If the radio started smoking when you tilted it....that means that there is something metal rolling around in there loose. Thats the only reason it should've shorted like that.
Good luck!!
Feb 16, 2011 | Magnum Radio Communications
2000 ford windstar...new battery, new alternator....still won't stay charged
Something is wired wrong draining electricity. Check the glove box light see if the radio works without the key. look for anything coming strait off of the battery not off of acc power.If it was a direct wire short out of nowhere the wire would have burnt up and been bare by now.Its somthing you have on or is staying on.
Apr 06, 2010 | 2000 Ford Windstar
Radio won't power up
The radio was most likely hooked up to power backwards. When you hook up the positive and ground wires wrong, it will blow the polarity protection diode in the radio.
The part is N1004 available at any radio shack. The number on the board is D23. It is located near the back right of the board when looking at the component side of the board. It may look black and burnt but not always. Replace it with another N1004 or better. If in a bind, you can just remove it and it will work again BUT!!!!
If you hook it up backwards again by mistake, it will ruin the radio.
Apr 03, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a HD52W55 and it will not come on. heard a pop and smelled something burning, took the back cover off can not find anything obviously burnt but have no lights and no power.
Well, my first guess would be a blow fuse, did you check for that?
But if you smelled something burning, then even if the fuse did blow, it failed to protect something; probably the main power transformer. That's a coil of wire in a sort of square shape that should be near the fuse. Its hard to tell if they're burnt sometimes, but it may need replacement.
Please upload a few pictures so we can have a look too.
Mar 25, 2010 | RCA HD52W58 52" TV
My magnum when i key up it blows the fuse,what could it be?
check your aerial for open/short circuit/power wiring to cb in truck/upgrade the fuse by 1 amp/mike wiring (tx/rx) if the cb shop could'nt find anything wrong then the faults in the truck/aerial/power? or the cb shops not up to much! you could have a faulty output transistor in the cb if all else fails?
May 09, 2009 | Magnum S6 Base CB Radio
I have power supply in hand
I experienced a similar problem with three FLM 2601 power supplies (from work). The two large caps that have hot melt keeping them in place are the typical culprits. They are located at one end of the module near the x-former.
Radio shack has the 35v 1000u caps for about $1.40 each.
Hope this helps.
Feb 22, 2009 | Polaroid FLM-2601 Television
Galaxy Radios DX-979 40-Channels Base CB Radio Logo
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
