Question about Kenmore Ovens
HOW TO REPLACE GLASS TOP ON KENMORE ELITE SLIDE IN RANGE MODEL #790.4671962
  • 4 Answers
SOURCE: Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Posted on Feb 17, 2009
greg_margo
  • 1959 Answers
SOURCE: kenwood elite glass top range
F7 indicates a stuck touch pad key. Try pressing all teh buttons on the key pad to see if one is stuck. If you don't have a stuck key, there may be a problem with the key pad module itself
Posted on Apr 19, 2009
  • 70 Answers
SOURCE: Frigidaire glass top range
yes u can.unplug the unit from power.remove the screws under neath the glass top at the from and lift the top up,hold it up using a piece of stick like u hold bonnet of car.then u can see all the elemnt and they are pretty straigtfoward to chg.
Posted on Aug 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite made by Frigidaire
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
SOURCE: Kenmore Elite slide in range model # C790-440732
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Posted on Nov 16, 2010
Kenmore 629.4677669
AppliancePartsPros.com
kenmore range/ cooktop/ glass tops. $80-200
good luck
Apr 16, 2014 | Kenmore Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
Feb 07, 2010 | Kenmore Ovens
How do i replace oven heat element? It is a GE Profile electric glass top range, model # JBP90WV2WW serial # ZM203767G
Turn off the power to the oven. Remove the oven racks. Unscrew the element retaining screws on the rear wall. Carefully pull the terminals out of the back wall of the oven. Remove the wires. Place the wires on the new element,slide it into the opening,tighten the screws,replace the racks,turn on the power.
Nov 12, 2009 | GE Ovens
Kenwood elite glass top range shows error code F7 for all burners.
Mar 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Kenmore glass top
Your range was actually built by Whirlpool. the first 3 digits of the serial number determine who it was manufactured by.
It's possible that a battery somewhere is running low. This battery would be for the clock and timer.
See if you can find the service sticker and find the model nnumber - it would most likely be a couple of letters and some numbers. If you're from the US, you may be able to find a manual here: http://shared.whirlpoolcorp.com/product_literature/search.jsp
If you're from the UK, it'll be here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Please let me know how you get on.
Jun 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
14 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
