Question about Philips Magnavox MWR10D6 DVD Recorder
Necant remeber how to finalize disk
Have a magnavox dvd player/recorder cant remeber for the life of me how to finalize a disk
Setup, Disc edit, Finalize
Posted on Jun 04, 2009
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My disc records fine, plays great on the Magnavox, but no other player can read the disc?
You must finalize a disc before it can play on other machines. Please refer to your documentation for how to finalize a disc.
Jan 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a magnavox mwr10d6 recorder. Errors keep coming up cannot record on disk e454037380
The disk might not have been finalized in the program that it was recorded on. If this is not the case unplug your recorder for 60 seconds and then plug it back in this resets the recorder.
Nov 12, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Finalizing dvd on Magnavox zv450mw8a
You have to finalize after each recording and it is okay to use autofinalizing. Thanks.
Feb 11, 2009 | Philips Magnavox DVD/VCR Dual Player
Is a Magnavox MWR10D6 DVD Recorder codec or driver needed to play DVD disks on computer?
There are work arounds... but the reason is when its burnt and finialized its written in .vob format which is dvd mpeg2 format. majority of windows media player codecs wont pick it up. divx does. its just the format its burnt in and you cant change obviously. you can just try like nero showtime which always works or ending up ripping the disc on the computier but that might defeat your purpost of burning them in the first place. Its not the dvd recorder i may add, its just the format. by the way its a magnavox unit made by funai... www.funai-corp.com/support and trust me your not going to get much out of their. your better off going into forums finding more high depth problems if you really want this to work for firends and families and such.
Oct 22, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd player
Are you using a DVD+RW disk? Unlike DVD-R, DVD+R and DVD-RW disks you cannot finalize DVD+RW disks on the Magnavox MWR10D6 DVD Recorder. Instead you have to make the disk compatable [Make Edits Compatible], this allows you to close the disk and play it on other DVD players.
go to: Setup ==> Edit Disk ==> Make Edits Compatible ==> Yes
Other than this nothing else comes to mind to troubleshoot this problem. Hope this helps.
Aug 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
I cant finalize my DVD recordings on my magnavox recorder.
Try this. In your SETUP options, ensure that AUTO FINALIZE and FINALIZE AT END OF TIMER are turned OFF.
Insert DVD to be finalized. Quickly press SETUP button. Be patient while DVD loads. (You will not see the "loading" bar on your TV screen. You will instead be mesmerized by the SETUP options!)
Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point. Picture quality is as good as the expensive DVD's.
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MWR10D6 DVD Recorder Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
