Question about Aiwa CA-DW50 Cassette/CD Boombox
Realistic SCT-74 tape deck has no audio - Aiwa CA-DW50 Cassette/CD Boombox
Replace a Tape Deck Belt
. Remove top lid (4 screws on the side)
2. remove the back plastic mount on the mechanics (2 pink long screws on the top). The bottom are two plastic hook lock. The mount pulls back and the belt and pulleys are exposed. NOTE: It is the mount you are removing, not the tape deck itself.
Jul 05, 2008 | Audio Players & Recorders
I need a servic manual for and optimus sct 86 Stereo cassette tape deck
Contact radio shack as that is their in house brand. I would suggest replacement as almost any other brand would be an upgrade over the optimus.
Aug 18, 2014 | Audio Players & Recorders
Chicago skywave
I have sent you an E mail. This is the best way to determine the problem
Oct 20, 2013 | Tascam 122MKIII Single Dual Cassette Deck
Knobs for realistic 909b
I am sure the parts have long past been unavailable so the best you can hope for is to get something that will work. Look at the offerings that are available at surplus electronics firms.
Mar 07, 2013 | Audio Players & Recorders
Hi having problem with my sta-2080 realistic receiver have equalizer and tape deck all realistic the volume on the receiver goes load and then soft with a lot of cracking sound the tape deck works good...
Is it just with the EQ (or any other single component) in the link? Old equipment develops oxidation on various controls. Depending on physical access, tuner cleaner may help. Or take it to a shop.
May 24, 2011 | Pioneer Audio Players & Recorders
I have a Realistic TR-3000 reel to reel tape deck. How do I get the front off so I can replace the capstan belt? dennis
You have to take the back cover off. You also have to take the knobs and guides off as well. The guides unscrew.
Once the back cover is off, there are about 6 screws that hold the cover on.
Mar 29, 2011 | Teac Audio Players & Recorders
Service manual for realistic STA-2080
I have a sta-2080 realistic receiver and wide range frequency equalizer plus a tape deck sct-22 all realistic.My problem is when i play the tuner or cd player witch is connected to the aux
the volume goes soft and then loud with a lot of cracking sound now ther is hardly any volume.when i play the tape deck it has it own volume control every thing is good so what parts do i need. thanks corneil
Nov 22, 2010 | Audio Players & Recorders
Where can i find the band for a optimus sct 5500 theyare sterched and the tapes won't play. i went to radio shack no luck
If you measure the diameter, you can work out it's approx size. Try searching for Tape Belts not 'bands' on E-Bay (I've seen plenty there) or the net and look for something the diameter of your machine or slightly smaller.
Aug 10, 2009 | Audio Players & Recorders
Tape Deck Belt Replacement
i dont have the model #, give me the model will try getting the picture.
Jul 16, 2008 | Audio Players & Recorders
Aiwa CA-DW50 Cassette/CD Boombox Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
