How to get optimus stav 3160 receiver out of protection mode
Protection Protection mode
SOURCE: Protection mode
I banged my head against the wall on this same issue and finally realized that my rear surround speakers were mixed. My rear right was wired to rear left because I was turning around to see L and R. It would shut off at about volume level 40, which was loud but not rumbling. It now ROCKS and is in no way a problem with heat. I have always run it with the cabinet open to allow air to circulate.
Posted on May 30, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
dunnbiker
  • 8546 Answers
SOURCE: amp comes on and goes
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Posted on Apr 06, 2009
SOURCE: Sony STR DE-725 going into ''protection'' mode
Audio Amplifier IC damaged
Posted on Aug 23, 2009
  • 336 Answers
SOURCE: ''Power off ''flashes ten times after the receiver is turned on.
Most often it will require an output IC, but I have seen it be a bad ground or a transistor in the protect circuit.
Posted on Oct 16, 2009
RCA STAV 3990 Power comes on but relay will not
Hi,your amp is going into protection mode.You need to have the amp module repaired or replaced
Nov 03, 2013 | Audio Players & Recorders
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
How i can connect a subwoofer to my Optimus Stav 3350,
Use a set of Bose speakers. The wiring goes from the speaker terminals on the amplifier to the sub. the right and left speakers connect to the sub.
Dec 29, 2011 | Optimus STAV-3350 Receiver
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
Sep 07, 2010 | Optimus STAV-3770 Receiver
How do I reset the protection mode on my Optimus STA 7500 Receiver?
You can not "reset" protection mode. This is an indication of a defect. Disconnect the speaker wires completely and if the protection mode remains, then the problem is internal to the unit and is likely to be shorted output transistors. Expect a parts cost in the $20-$50 range for this repair.
Dan
Mar 26, 2010 | Optimus Audio Players & Recorders
Optimus stav 3250 receiver - "protection" light keeps coming on. nothing blocking airvents. When I turn it past 10 it shorts out -
I have the same amp,, my trouble was a shorted out speaker,, wouldnt short out @ low volume,, crank it and the protection light would come on....
wasnt easy to find which of the 16 it was,,4 per cabnet X 4 quad set up ,, turned out to be a shorted tweeter...
Mar 01, 2010 | Televison & Video
Muting engaged on power up
This not muting, but protect mode. This means that a problem was detected internally and the unit has shutdown to prevent further damage. The most common cause of this is a failure of the output transistors. Expect a parts cost inthe $20-40 range for this repair.
Dan
Feb 04, 2010 | Optimus STAV-3770 Receiver
I need a replacement remote for a optimus stav-3680 audio video receiver
Optimus was sold only by Radio Shack. It would be a special order. Get the catalog # from the rear of the receiver (31-XXXX)
Dec 11, 2009 | Optimus STAV-3690 Receiver
Oct 16, 2009 | Optimus Audio Players & Recorders
83 people viewed this question
 Grubhead
Grubhead
