Question about GE JES0738 Countertop Microwave Oven with 0.7 Cu. Ft. Capacity, 10 Power Levels, Electronic Touch
Terrible burning odor
Had a terrible odor, like burning electronics. Took off cover, noticed plastic sheath on connector to thermal cutoff is melting. Unit still works, but terrible odor. How do I fix this?
3 Suggested Answers
  • 43 Answers
SOURCE: burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Posted on Jan 26, 2008
heatman101
  • 43501 Answers
SOURCE: ge spacemaker xl 1400 microwave stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Posted on Sep 30, 2010
My Kenmore Elite model 665.61689 smells like burning plastic inside each time I use it. The vent inside gets very hot, but not sure if it did that prior to noticing the odor.
The smell could be caused by many things. Usually it's the high voltage rectifier, high voltage transformer, or wave guide cover. If you can see the latter, then you can determine if it's burning. If it's the h v rectifier, it should be failing completely very soon. H v transformers are sometimes slower to fail. Whatever it is, it should be repaired asap as there is a risk of it catching fire.
Sep 24, 2016 | Kenmore Microwave Ovens
What is the cause of the smell of burnt plastic coming from my kenmore elite microwave?
Frequently this is caused by a loose connector to a thermal protection device (a TCO) or some other connector that has a plastic sleeve over it. The connector is loose, which is causing heat, which is melting the plastic. You would have to remove the cover to find the bad device and connector. This is a job for a professional microwave repairman.
Jul 23, 2014 | Kenmore Elite Microwave, Model...
Jmc8100adw died
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 30, 2013 | Jenn-Air JMC8130DD Microwave Oven
Hotpoint over range microwave has no power
Nov 29, 2013 | Microwave Ovens
Hotpoint over range microwave has no power,
Wolf microwave timer counts down, lights on but not cooking or making noise when started
You need a magnetron. While the cabinet is open look for melted wires, check the circuit board for burned components. Check thermal cutoffs for continuity etc
Nov 26, 2013 | Microwave Ovens
GE JES1145DP1WW does not heat but operates normally. Has burned out HV fuse and not sure how to measure this Rectifier. Looking for any experienced Technician with this model.
please make this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Oct 28, 2013 | GE Microwave Ovens
It lights up but the buttons won't work, what is wrong with it?
Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. If the magnetron was making louder noises prior then replace the magnetron. the giant capacitor could be bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Jun 12, 2013 | Emerson MW8778 Microwave Oven
GE JES0738 Countertop Microwave Oven with 0.7 Cu. Ft. Capacity, 10 Power Levels, Electronic Touch Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
