Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 chevy pickup running temp
We replaced the motor in a 97 chevy pickup 350 5.7l and the temp is running around 210, is that a normal temp or should I be looking for a cooling problem
  • 33 Answers
That's not really that unusual of a temp. 195-210 is a normal range. If you'd like, you may try installing a 195 degree t'stat. As well, make sure your cooling system, (radiator, heater hoses, and water passages in the block) are in good order. If this engine previously used the "orange" GM coolant, they were bad to clog up hoses and passages. I had to take all my hoses off, as well as water pump and thermostat and run pressure hose through all the orifices to get the gunk out.
Posted on Jun 04, 2009
My 02 chevy cavalier overheats without a sign of leaking coolant
Not sure I am with you on this. The cooling system is designed to run between 190 and 210 as a normal range. Above 210 and the radiator fan should start up. Anything over 230 is considered Hot.
Is the radiator fan coming on around 220 degrees ?
Aug 04, 2014 | 2002 Chevrolet Cavalier Coupe
Thermostadt was stuck open replaced thermostadt now it runs just a little hot
Yes, try a 180 thermostat, with a 195 the fans will not turn on until about 210.
Oct 05, 2012 | 2003 Chevrolet TrailBlazer
1978 chevy 350 what temp should it run ? before it runs hot.
180 to 195 is good if its running around 200 its considered hot over that around 210 215 is overheated
Jun 30, 2012 | Cars & Trucks
Coolant temp rise to around 210 degrees when idling or in stop & go traffic bur drops back to around 196 when cruising. Is this normal?
completely normal those readings are perfect this car comes with a 195 degree thermostat,210 is fine for stop a go traffic remember a cooling system with the proper amount of coolant in it and under pressure will not overheat till about 240 degrees your in great shape no conerns!!!!!...
Sep 01, 2010 | 2006 Chevrolet Corvette
1995 Chevy Tahoe 5.7L V8: thermostat temperature/running temp?
Depends on what thermostat you put in. Stock is a 190*. Which will usally run about 200-210. That's where most all small blocks are happy.
Nov 09, 2009 | 1995 Chevrolet Tahoe
What should be the heat temporture on a 5.7 motor ?
The temperature should be running in between 200 and 210 degrees and the easiest thing and cheapest would be to change the thermostat try that out and let me know also if you get a chance if you can rate me if your satisfied.
Thanks,
Steve
Jan 03, 2009 | 1999 GMC Suburban
Running Warm
It sound like either the cooling fan clutch is not operating properly or the radiator needs to be pulled and roded out by a radiator shop, 1 other thing, are you sure the temp guage is accurate? you can test this by using a scan tool on the engine control computer, tap into the ECT sensor for the injection.
Aug 11, 2008 | 1996 Chevrolet K1500
Thermostat
Normal temps for your car should be around 205-210 degrees.
The thermostat should be located on the bottom radiato hose, where it meets the engine. trace the hose from the bottom of the rad. to where it connects to the motor and you should find the thermostat there. usually on the back side of the engine around the intake manifold
Aug 11, 2008 | 1997 Nissan Maxima
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
198 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
