Question about Hardware & Accessories
How to wire a dayton 5WMK0 - Hardware & Accessories
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
Sep 28, 2012 | Dayton Permanent Split Capacitor Motor Fan
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
How to wire a 1dgv1 speed control to a 1tdu8
You will wire this just like a single pole light switch, take your power from your panel (black) to one of the pigtails or set screws and then take another black wire leaving the speed controler to your blower motor. Take the common/white wire directly to the blower, polarity sould not matter which leads you connect them to in the blower.
Oct 09, 2009 | Dayton Dryers
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Dec 07, 2008 | Dayton (3E379) Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Hardware & Accessories Logo
90 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
