Question about Toshiba Satellite M105-S3004 Notebook
Keyboard For some reason i cannot do anything on my laptop because its keeps inputing the letter f. I cannot press any other letter i can only click my mouse and move the cursor. I can't access the admins. because i cannot type in my password i can only go into the guest profile?
  • 65 Answers
Replace the keyboard as it seems the F key is probably jammed.
Posted on Oct 18, 2007
This afternoon my laptop was working fine, then the keyboard started messing up, when I pressed any letter it came up with 4 other letters. Then i pressed '9' once and it continuously typed 9 until I
First thing I would ask is this. Was anything spilled on the key board? I had a situation similar to this and I found that my son spilled a Sprite and wiped it up but didn't tell me about it. One way to check this is to hook an aftermarket keyboard that runs off your USB2 port and see if the keys work correctly that way. If they do, I would suspect that something was spilled into your laptop keyboard.
Feb 06, 2013 | Computers & Internet
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
Space bar and certain letters not working keep pressing keys and other letters keep popping up
First Open your Control Panel and go to regional and language options
And Click on the languages tab as shown
Under text services and input languages click details
Make Sure Your Default Input Language is Set To English US (RED)
And your Installed Services looks like this (green)
Jun 06, 2011 | ASUS Eee PC 1000H Laptop
Multiple letter input in one letter
hi neriz, i believe what you meant by "multiple letter input in one letter" is that when you press a key, say the letter A, it comes up with AAAAAA on the screen, is that right? if its so, its called "sticky keys". the keys on your keyboard are stuck either with dirt, dust, food crumbs, or if water has been spilled. you can try vacuuming the keyboard or shaking it face down the table to get rid of dirt inside or under those keys. try pressing other keys aswell, if all of them acts the same way, you may want to change the keyboard settings on control panel. but if its just a couple of keys then yes, it is dirty. if this is not your case, let us know ok?
Apr 05, 2011 | Samsung N150 (36725723009) Netbook
Got an HP Laptop. Need to change language of keyboard to English as when I press a symbol, it brings up an incorrect one.
In the bottom right hand corner of your screen (on the taskbar), you'll see either a symbol of a keyboard (Windows Vista or Windows 7), or two letters together (Windows XP). This symbol represents the language you're currently using for your keyboard. Click on that symbol with your mouse, and select which language you'd like to use (In this case english) to resolve this problem
Mar 05, 2011 | Computers & Internet
My other laptop keeps repeating the letter I press like when I go to google search and type 'h' it will go hhhhhhhhhhhhhhhhhhhh forever and not let me type anything or delete.
Hi, this is a common problem with sticking keys, caused by a spillage i.e a drink onto the keyboard. The keyboard will need cleaning or replacing.
Aug 07, 2010 | Computers & Internet
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
Its typing numbers when pressed letters
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 10, 2009 | HP 386209-001 Keyboard
Keyboard error
Sounds like the F key is stuck. If you can get the keytop off, you may be able to fix the problem. If not, you may need a replacement keyboard.
Hope this helps!
R-
Oct 18, 2007 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3004 Notebook Logo
158 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
