Question about Samsung Digimax S730 Digital Camera
Flash doesnt work
Flash doesn't operate
Turn signal flasher oldsmobile achieva 94 not flashing how do i fix
light goes on but doesn't blink is typical of a bad flasher unit. Flasher units usualy have two wire connections. Flashers can be round or square. Try replacing flasher with another known working flasher unit.
Apr 30, 2012 | 1994 Oldsmobile Achieva Special Edition
When I insert My transcend flash and then one message alert, USB DEVICE not RECOGNIZED? Please kindly recommend and solve this problem. Thanks for your help.
your operating system has got corrupted or infected by virus. install good antivirus and go for boot scanning. if it doesn't work, reinstall your OS.
Jun 18, 2011 | Computers & Internet
Only ocationaly rebooting the system. most of the time it says operating system not found.what could be the reason.Please help.My system Fujitsu seimens amilo pro 2065
Hey, either a hard disk corruption or some missing/corrupt files - Solution: Format and reinstall your Operating system. If that doesnt work, maybe you need a hard disk replacement.
But before that, are you sure you haven't connected any USB drives or flash drives or an external hard drive when you computer boots up. That could be the reason. Solution: disconnect any such device before you start your computer.
May 21, 2011 | Fujitsu Siemens Amilo Pro V2065 Laptop...
I have an hp dv6700 but it doesnt want to work because when i turn it on it says configured stage 3 of 3 0% complete and it turns off
It is possible that the computers operating system has become corrupt for one reason or another, my guess is that your computer is over 3+ years old(dv6 series is old) if formatting and reloading your operating system doesn't fix this issue, it may be your hard drive that has failed(or failing)
May 06, 2011 | HP Televison & Video
I want samsung chat 322 themes and games but it does not suppot .what can i do
Nothing, if your system doesn't support it, it doesn't support it. It's like Flash on Apple products, other than hacking (jailbreaking) the devices, Flash will not work on iPods, iPhones or iPads. I must presume that if you had the the technical skills and experience to hack into your device, you wouldn't have asked the question, so that option is not for you. Sorry.
Apr 27, 2011 | Computers & Internet
My internet works but when i go to view a video it tells me i need a flash player but i have installed it three times and it does'nt work
Click On Start >>> Run >>> type in Macromed >>> Double click on the Flash folder
>>>Double click on the Falshutil icon to update the flash player and then restart the computer
If it doesn,t works :
Try go to the adobe.com and upadate the flash player from there
Mar 12, 2010 | Computers & Internet
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
How to fix Camera doesn%27t work with MSN
You probably need to update your Adobe flash software, get it here and try to connect to MSN again >>>>>>
http://get.adobe.com/flashplayer/
Good luck
Jun 22, 2009 | Computers & Internet
The flash doesn' work
Hi
Either your flash unit is defective and needs to be replaced, or the mainboard is defective and causing the flash to not work. The only way to know is to start with the flash and replace it, if that doesnt work its the main PCB.
We are an affordable digital camera repair business, if we can be of any assistance with the repair please let us know!
Good luck from Darntoothysam com
Thomas
Oct 25, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Samsung Digimax S730 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
