Question about Home
Quartz clocks not keeping proper time
I have TWO different quartz wall clocks (just simple round ones, about a foot or so in diameter), and they both worked fine for years. Now, I've got them both in my new classroom (I'm a teacher and I've just moved to South Carolina from Nashville, TN), and BOTH are acting flaky. They both seem to run fast, but not exactly the same, and it seems to vary. Any tips on how to fix this? (Obviously, I've tried replacing batteries, but this doesn't work.) I'd appreciate any help!
On the front of one, it says ''Ingraham USA'' with Takame USA on the little box on the back where you put the single AA battery; the other is just says ''China'' (in addition to ''Quartz'') on the front, and something about ''unadjusted'' and ''Made in China'' on the little box on the back where you put the battery.
I don't think either one was extraordinarily expensive, but one (the China one) has sentimental value and I'd love to get it fixed!
Thanks in advance...
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
informatica
  • 1114 Answers
SOURCE: 12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 31, 2008
Fixe_You
  • 1800 Answers
SOURCE: Bose radio display doesn't show at all
take it apart and use alcohol and a tooth brush to clean the lcd connector and lcd IC.
Posted on Jan 21, 2009
  • 105 Answers
SOURCE: my sony radio alarm clock is too fast about 1 hour
alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
Posted on Jun 04, 2010
SOURCE: seth thomas autoset wall clock not functioning.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Posted on Jun 10, 2010
Equity model 29002-1
Anon, replace battery with a good strong AA Energizer or Duracell Alkaline not a cheap battery, make sure battery contact point in clock are clean and no corrosion. If this does correct the problem, the clock mechanism is probably just wearing out from age which is normal unless it is digital. Read through the links and learn how some time mechanisms can be made to work properly again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Maintain Battery Powered Quartz Wall Clock
Save Money Quartz Battery Wall Clock Repair Fixing Disney Winnie The Pooh...
Clock repair and troubleshooting
How to identify and replace quartz clock movement
Feb 15, 2014 | Equity By La Crosse Equity 29003 10"...
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
Jan 13, 2014 | Westclox 47550 Quartz Loud Bell Analog...
My clock chimes the correct amount of chimes on all hours except 7. At 7 it chimes 5 times
In a quartz movement clock, with a problem like this, the chime box (or whole movement) will need to be replaced. Timesavers.con carries a large selection of chiming quarts movements.
Jan 12, 2014 | Howard Miller Greer Chiming Quartz Wall...
Bulova wall clock hands won't move
I haven't much experience of this type of clock. A friend has such a quartz pendulum clock and I was surprised to discover the pendulum has no direct mechanical contact with the clock motor and as long as the motor draws some current from the battery the pendulum will swing due to the resulting influence of a small electromagnet.
I guess the quartz mechanism is at least electrically ok but somewhere there is a mechanical fault preventing the hands moving.
A typical quartz clock motor is fairly simple and dismantles easily to reveal only a few internal parts that can be examined under a magnifier to determine the probable fault - dust, burrs or excessive wear.
It is also worth making certain the clock hands do not bind on each other or the clock face.
Jul 08, 2012 | Home
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 | Watches
Home Logo
100 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
