Question about Belkin Wireless-N Wireless Router with 4-Port Switch
LOST 192.168.2.1 OPTION
Getting a limited or no connectivity error because the network did not assign a network address to the computer - can't get onto 192.168.2.1 either - think i mucked that up when playing around and reset the IP but can't get in with that either
  • ros1916 May 20, 2009
    Thank you you are a star - all fixed
    Problem Solver:
  • 12 Answers
Hold the reset button on teh back of the router for 10/15 seconds, will factorty reset, you shud be able to access the router login page
Posted on May 18, 2009
What do you mean about talking to the router?
Posted on Aug 21, 2009
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Ip address in invalid on windows vista
All we need to do is to reset the router for about a minute, if we are still getting invalid IP which is 169.x.x.x then we need to temporarily assign an ip address on the computer.
How to assign IP address:
Windows XP
Step 1: Click Start, then Control Panel.
Step 2: When the Control Panel window opens, double-click Network Connections.
Step 3: Right-click Local Area Connection, then click Properties.
Step 4: When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then Properties.
Step 5: Change the option from Obtain an IP address automatically to Use the following IP address and enter the following:
Make sure the IP Address you'll be assigning the computer has the same first three numbers as the Default Gateway and the last number can be any number between 2 and 99. In this example, our Default Gateway is 192.168.1.1, so the IP address that should be used must start with 192.168.1. In this example, the IP address that we'll assign is 192.168.1.50.
  • IP: "192.168.1.50"
  • Subnet Mask: "255.255.255.0"
  • Default Gateway: "192.168.1.1"
After assign static IP then click OK.
Step 6: If we are not getting any response from the router(like pinging the ip address of the router) then possible product is defective.
Dec 22, 2010 | Computers & Internet
Netgear DGN 2000 won't connect to internet by cable / wifi works
Might I suggest looking at the routers configuration. This can be done by typing in 192.168.1.1 into your web browser. Typically the default log in is: User Admin, Password is password. You want DHCP set on. Save all your settings. Then reset to factory default. There should be a reset button on the router. This will reset it to when it was new- any changes you made will be gone.
Oct 11, 2009 | NetGear DGN2000-100NAS Router
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys USB adapter not working
Check your device setting on the adapter and make sure they are set to get IP automatically. The check the router and verify that it is set to assign address by DHCP and that you have not exceeded your capacity. Some providers may have set a limit and the new device is not getting an address because there is not a free address. Your other option would be to assign the IP manually and connect. You might also try changing the channel your router is using to communicate on. This has been an issue with channel 6 on Cisco routers and HP machines in my area.
Aug 23, 2009 | Computers & Internet
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Dynex 4 port Hub
Try to assign an IP address to the second computer like 192.168.0.101 Subnet 255.255.255.0 and Default gateway 192.168.0.1
Note: This one is an example of IP address, the IP address that you need to assign is in range to the router that you have or with in range to the modem.
Mar 08, 2009 | Computers & Internet
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
Limited connectivity
A network hub allows computers to be connected together...up to 12 of them in this case...but it doesn't provided any other network services such as DHCP (automatic address assignment). I may be able to provide better information if you can tell me what operating system you're using.
Here's one way to set up a network for file sharing...if you're using Microsoft Windows1.gif XP:
Connect the computers to the hub and turn them all on. You may need to manually assign addresses to the computers, (ask if you need a detailed procedure) but Windows XP will usually assign itself a default address.
On each computer, click on Start -- Control Panel -- System -- Computer Name -- Network ID -- Now give the computer a name and Workgroup name. In order for the computers to share files1.gif, the workgroup names must be identical on every computer.
Next, click on My Computer and Right-Click on Shared Documents -- Sharing & Security -- Share this folder on the network
Now if you click on My Network Places, it should be possible to see the shared folders on the other computers.
Good luck with this....and I hope this is helpful!!
Jan 23, 2008 | 3Com LinkBuilder TP/12 Networking Hub
Limited or no network connection
looks like the dhcp is your problem.
the error is telling you that its an internal network providing limited access.
go to run cmd then in the dos prompt type in ipconfig /all
see your network card's ip address. if its 169.x.x.x then thats the problem..u are not getting the ip address from your computer.
go to your network connections right click the network card then go properties in the tcp/ip area assign yourself a manual ip address of 192.168.1.xx
the xx is a number that u like 2 digits only but it can't be 1
your default gateway is your router so give it 192.168.1.1
this should solve ur problem
good luck
smeags
Jan 19, 2008 | Linksys Wireless-G Broadband Router
Open Questions:
Belkin Wireless-N Wireless Router with 4-Port Switch Logo
200 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
