Question about Cuisinart TOB-30 Toaster Oven with Convection Cooking
Bake does not work - Cuisinart TOB-30 Toaster Oven with Convection Cooking
Bake no longer works
Have the same problem, someone please answer
Mar 11, 2012 | KitchenAid KCO222OB Toaster Oven
The toast part works but the bake and broil does not work , the blue light does not come on and no heat is produced
We've got the same problem and I just took ours apart.
Bad news: I'm pretty sure it's the circuit board. It's not the timer knob, and I'm almost positive it's not the upper selector knob. Most of the components on the circuit board are only used for the "bake" mode to regulate temperature. The board is marked, "128301 Timer PCB". I looked into whether one can buy a replacement board from Kitchenaid, but it's not on their parts list. If I had to guess, I'd say it's the relay on the board, but it's only a guess. Shoddy components, plus it gets hot in there and "bakes" the board. The little fan in the side isn't part of the "convection." It's for cooling off the circuit board. Don't laugh.
Even worse, next to the thermostat on ours, there's a little rubber insulator that's burnt to a crisp. The connection under this insulator was also loose. It hasn't affected functionality, but it doesn't instill confidence in the design. Kind of scary. Unplug this unit when not in use!
Only a one year warranty. I think we now have an expensive toaster.
Jul 24, 2011 | KitchenAid KCO1005OB 1400 Watts Toaster...
How to bake pizza lost our manual
Hope someone helped with baking the pizza. Otherwise, you can try manualsonline.com to see if they have your needed manual.
ToasterandConvectionOvens.com
Feb 12, 2011 | Bella Cucina 13049 1500 Watts Toaster Oven...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
BLACK & Decker Countertop owen Model: CTO 649 does not work
Try smallappliance.com for your parts or just google search "small appliance parts" and you'll see a few places that have B&D parts.
Sep 19, 2009 | Black & Decker CTO649 Toaster Oven with...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Dec 05, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Cuisinart TOB-30 Toaster Oven with Convection Cooking Logo
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
