Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
350 leaks gas when filling
  • Jim Parker
    Jim Parker May 11, 2010
    Do you still need help or have you figured out the problem? Where does it leak from?
    Jim
  • Håkan Sterner May 11, 2010
    Where does it leak gas then? Some slobbering is always to be expected when filling but I gather you mean it leaks in strange places. What is strange to me is that it wouldn't continue leaking after the filling and the cap is closed. There is a tank vent, sometimes small amounts of gas may leak here but this is nothing to worry about. Please elaborate.
  • 86 Answers
HI. I JUST TOLD A GUY THAT THAT HAPPENED TO ME AND IT WAS THE FUEL LINE, IT POPED OUT OF PLACE. HOPE IT HELPS. JIMBO
Posted on Sep 14, 2009
  • ray matay Dec 09, 2011
    I have the same problem with the tank vent but it keeps popping back out causing fuel to leak from the vent hole. Thoughts on how to fix?
What caused A/C to fail?
something wrong with what you say
no freon --ok --that is a leak
next you say that after 30 minutes on the vacuum pump the system showed no leaks
did you have the leak fixed before vacuuming it down -
next--- what gas did you recharge the system with
was it the right gas--- as 350 psi is really high
Gm ac systems are pretty efficient unless they are worked on by any one other than accredited ac specialist shops
I suggest that you visit one to get to the base of the fault
Nov 19, 2015 | 2002 Chevrolet TrailBlazer
A 94 f 350 fuel exchanging between tanks
there is no equalising between tanks and all the return fuel from the injectors is being contained in one tank. Try shifting the fuel return line to the tank that you are not drawing out of so that the fuel then flows into the tank that the pump is drawing from. Check that the tap/ s between tanks is turned on.
Mar 08, 2014 | Cars & Trucks
Gasoline smell in car
You may have leakings fuel line on top of gas tank when filling up or line is leaking where they connect to fuel filter under body maybe behind rear wheel wells , or may have a leaking furl injector or even your carbon gas canister filtr need chaging or ovver filling can send fuel up to that canister which recirculates gas fumes back to fuel system check your gas cap maybe leaking or when gas attended over filling it runs down into drain tube
Joe
Oct 08, 2012 | 2001 Pontiac Grand Prix
Gas leaks out of husqvarna 350 when in use
when you refer to using it i take that as your motor is running properly which rules out the fuel supply lines, and the primer bulb .. probaly one of two things check the gas cap and make sure it has a washer and makes a liquid tight seal and inspect the tanke for any hairline cracks that begin to drip when the motor is at idle, if it could also b the primer return line that vents back to the tank ethanol has a bad habit of eating up fuel lines on two cycles
Apr 13, 2012 | Husqvarna 350 Rancher Chain Saw
Gas leaks out when chainsaw is tilted and in use
sounds like you have a cracked fuel tank or stripped out gas cap
Apr 13, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Need gas/oil ratio for Husky 350. Thanks
50:1 is the correct ratio. Be sure to shake the fuel can just before filling each time to prevent oil starvation. Don't make up more than a gallon at a time unless sawing is your business. Always use fresh fuel and a modern synthetic saw oil. Hope this helps!
Oct 18, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Check engine lite on 98 chevy k1500 code is gas tank CHEVROLET PICKUP 4x4 350 extended cab
Check the gas cap is sceruely fastened, check for leaks in the filler tube for gas tank, and check for leaks in the hoses/tubes to the evaporative canister.
Oct 30, 2009 | 1998 Chevrolet K1500
Engine light comes on and off once in a week.sent to dealer and they change oxygen sensor ($350)didnt work.my regular service to dealer is done on time. I also top up my gas evry day to avoid condensa
Hi, first off don't ever top off your tank I don't know who told you to do this but this is a bad thing. This by itself will cause your engine MIL to come on most likely with a code PO455 large evap system leak. by topping off your tank you are installing a problem on your own vehicle what happens is as the gas heats up it expands normally there is enough room at the top of the tank to stop overflow, but when topped off it overflows into the charcoal canister and starts leaving a caron buildup in your granulated charcoal and will render it useless and a replacement will be necessary. also make sure you clean your gas cap off very well with alcohol. As this by itself can cause your MIL to turn on intermittently and set a PO442 small evap leak code.
May 28, 2009 | 2005 Honda Civic
Husky 350 leaking gas from white plug in gas tank
I have a rancher 55 and it was leaking gas, i replaced the gas cap. That solved the problem.
Sep 30, 2008 | Garden
Gas tank filler hose on Ford E Super Duty Motor Home
Look again into the fuel filler there should be a metal hose which is where the tank gets it's air from, ensure when your filling up your not pushing the fuel filler gun fully home when filling up, suggest you don't fill the tank right up to the very top as your correct it's a big job & you will need parts before you take the tank off. http://passionford.com/forum
Jul 03, 2017 | 2007 Ford E-350 Super Duty Length XLT
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
336 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
