Question about Dell Vostro 1014 Laptop Computer
Qmi module not exist in LG
Wifi
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: i've dell vostro 1014 n my wireless network is not
The wireless card may not be included in your laptop or the wrong wireless card driver was installed.
I suggest you dowmload the driver usin=gf the Service Tag number.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Sep 12, 2010
  • 2567 Answers
SOURCE: wi-fi is not working..while installing
Sounds that the wireless adapter daughter board is either loose or failing. First, we need to make sure it is making good contact with the laptop's motherboard. In order to do this, we have to do the following:
1. Turn off the laptop & remove the battery.
2. Look at the compartments in the bottom of the laptop. You should be able to see 2 or 3 areas with small rectangular plates covering them. These plates usually have one or 2 screws holding them in place.
3. Check which one of those plates is the one which covers the wireless adapter daughter board. When you find it unscrew its screws & remove it.
4. Below the plate, there will be a small daughter board screwed to the laptop's motherboard, with 2 thin wires attached to it (usually one black wire & the other is a white wire). Gently, remove both wires using a small flat screw driver to pull them out gently. Don't forget to note down which wire connects to which connection point.
5. Unscrew the wireless adapter daughter board & remove it from its slot.
6. Clean both the slot & the daughter board's terminal connectors using a dry electric contact cleaner. You can purchase it at an electronics store.
7. Leave the slot & the daughter board for a while to dry.
8. Re-place the daughter board back in the slot & screw it to the motherboard.
9. Reconnect the 2 wires.
10. Screw back the covering plate.
11. Put back the battery & turn on the laptop. Check if the problem was fixed.
If this did not fix the problem, you will need to repeat the steps to remove the wireless adapter daughter board & replace it with a new one.
Posted on Oct 27, 2010
  • 629 Answers
SOURCE: I have purchased DELL N
go to support.dell.com, click drivers and downloads, enter your service tag and look under network category and download the correct driver for your wireless network card.
Posted on Feb 20, 2011
While installing my wireless driver in my dell vostro 1015 laptop i face an error " QMI module not exist? " any help?
On a dell they have either a hardware switch or a ALT-? key combination to turn the wireless on, normally it's a hw switch on the front or one of the sides with an antenna symbol. Look at the color of your ALT key and then look for the Antenna symbol or wifi symbol, Either of them should toggle the power to the wifi card.
also you can hit the windows key and look on the right side of the pop-up and find the computer link, right click on it and open properties then Device Manager, look for anything with a Yellow Triangle on it It may say Unknown Network adapter, right click on it and select properties, and then the driver tab, click update driver and explore and find the C:\Dell\drivers or c:\drivers directory and reload your wifi driver. Good Luck
Feb 21, 2015 | Dell Vostro 1015 Laptop
LG BP200, added password to wifi, Netflix cannot connect
Try first out another provider. If the problem still exists than someone is jamming it or cracked. In this case you should get new gear. However if it worket without the password why did you put one on?
Apr 16, 2014 | LG Super Blu BH200 Blu-ray and HD-DVD...
I have purchased DELL N 5030 and install XP on it. Now WIFI driver is not installing on it. It is showing error QMI Module does not exit. Kindly help to resolve this issue.
Feb 20, 2011 | Dell Computers & Internet
Hi, I have a Benq joybook Lite U101 series and the wireless module can not see by the Windows 7 and also XP. Every time when I have started to install the driver appear this message "QMI module not...
Hi, I repair a Benq joybook Lite U101 series and the wireless module can not see by the Windows 7 . Every time when I have started to install the driver appear this message "QMI module not exist".
Jan 04, 2011 | BenQ Joybook 3000-01 Notebook
I've dell vostro 1014 n my wireless network is not working,i tried to install wireless driver but its showing that qmi module not exist..what should i do? please suggest.
Sep 12, 2010 | Dell Vostro 1014 Laptop Computer
I hav a probem in installing the wlan driver whenever i set up an error comes i.e qmi module not exists..plz tell the solution
The driver has to be installed manually but i need to know what model your computer is as this is usually to do with Dell laptops.
If you already have the driver downloaded then you need to right click on it and extract the contents to a file (download Winrar if you need to extract it)
Once extracted right click on computer/my computer and select manage from the sub menu, then select device manager.
Right click on the network driver you need to install and and select update driver. Then use the wizard to navigate to the folder that you have the extracted files in and click Ok. The machine should now install the WLAN drivers for you.
Alternatively you could use an Ethernet cable and perform a Microsoft Update instead.
Good luck and please post back if you need anymore help.
Regards.
Jun 25, 2010 | Computers & Internet
Lg wi fi
Did your laptop definitely come with a wireless module inside? Sometimes manufacturers will use the same chasis for the cheaper laptop with no WIFi so you will see the wifi switch and indicator light but there is no module inside
Jun 27, 2008 | Computers & Internet
Dell Vostro 1014 Laptop Computer Logo
295 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
