Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Control housing - Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Where is the breaker to the oven is it a certain breaker that controls the oven or s it the breaker controls the house like the lights and the TV and the main things that controls the house
The breaker for the over is normally in the main house fuse panel. Be very careful when working on any electrical feed for your oven, that is normally a 240v outlet.
Dec 24, 2014 | Frigidaire Ovens
I have a kenmore side by side. FF side too cold. Replaced t-stat and defrost timer. All settings and air flow set right. FF still too cold. T-stat set all the way down . Should be at 3 or 4
You need to provide a model number in order to look over the parts list and see what type of auto damper your model has. There are ways to test an auto damper to see if it opens and close properly. An auto damper can be electrical or mechanical. Kenmore model numbers look like this example=> 321.2345789 and can be found artound the fresh food compartment door frame.
1 Turn power off to refrigerator.
2 Open the fresh food sections door and remove all items on top shelf.
3 Adjust the fresh food control to its coldest position.
4 Remove the light shield by pulling down on the back corners of the cover and then slide the cover forward.
5 Remove the edge sealing device, radiant shield supporting screws at the back bottom center of the control housing mounting screw at back, bottom center of the control housing. Slide the control housing to the right and lower the housing.
6 Disconnect the temperature control housing from electric quick disconnect.
7 Remove the temperature control housing from the refrigerator and then place on a
flat work surface.
8 Remove the auto damper control rod retainer, control rod and the slide control
gear from the auto damper control.
9 Now turn the control housing over.
10 Remove the two auto damper mounting screws, then remove the auto damper from the control housing.
11 Mark the auto damper rod about 1/4 in. from and away from the housing.
12 Uncoil the auto damper capillary tube at about 4 in.'s
13 Submerge into a glass of ice (not water). then watch for door to move to the closed
position.
14 Remove from ice and warm capillary tube with your hand. Then watch door for an opposite reaction.
15 If no movement is detected, replace the control. 61005971 Damper Control Assembly
The above is only a demostration of how to test a refrigerator with an auto that uses a capillary tube to open and close the damper. Your refrigerator will need to be identified by the correct model number to let you know what type of auto damper your model has, Post your model number and I will tell you what you will need to test yours, Thanks Sea Breeze
Apr 12, 2013 | Refrigerators
HOW MANY LIGHTED HOUSES CAN BE HOOKED UP TO A BACHMANN CONTROLLER
You don't have enough power with a single controller to provide enough power to light all your light houses. You need to figure out the power draw & get a separate power supply.
Dec 14, 2011 | Bachmann Toys
How to change blower motor in. 99 grand Cherokee
Check this procedure...Blower Motor Resistor and Controller Replacement
REMOVAL
1. Disconnect and isolate the batten' negative cable.
2. Depress locking tab and unplug the wire harness connector from the blower motor
resistor or controller (power module).
3. Depress locking tab and unplug the resistor or controller connector from the blower
motor.
4. Remove the 2 screws that secure the blower motor resistor or controller to the
heater-AC housing.
5. Remove the blower motor resistor or controller from the heater AC housing.
INSTALLATION
1. Install the blower motor resistor or controller to the heater AC housing. The
housing is indexed to allow (controller power module) mounting in only one
position. Tighten the mounting screws to 2.2 Nm(20 in. Lbs.).
2. Plug in the wire harness connector to the blower motor resistor or controller.
3. Plug in the connector from the blower motor resistor or controller to the blower
motor.
4. Connect the batten' negative cable.
Hope this helps (rerember to rating this and leave a testiomonial).
Sep 30, 2011 | 1999 Jeep Grand Cherokee
My pool light turns on by itself a lot. Almost every day. I don't have remote for it so I have to manually turn it off. What are the dials for? Can I disable the remote. I think a neighbor might be...
The dial with the letters is for setting the "house code". The dial with the numbers assigns a number for each controled device. If your neighbor's house code is the same as yours it is possible that their controller is tuning on your light. Change your house code to another number. Remember that all controllers and controlled devices must be on the same house code to work, so you have to change the house code on the remote also. If you don't want the remote to work just set it to a house code letter that is not being used by anything else. If you don't want the remote to work just for that device, just change the device number.
Jan 16, 2011 | X-10 X10 Pro PLW01 Standard Toggle Single...
How do i change blower motor resistor on 99 jeep grand cherokee
Welcome to FIxYa.com
Image Blower Motor Resistor Or Controller/Power Module Remove/Install
REMOVAL
motor.
heater-AC housing.
INSTALLATION
motor.
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 22, 2010 | 1999 Jeep Grand Cherokee
Blower motor resistor, where is it located/
It will be up under the dash on the passenger side near the blower motor. It will have 5 or six wires in its connector
Nov 10, 2010 | 2000 Jeep Grand Cherokee
The light in the refriderator has no power getting to it and the temp display has no light showing
You have a Whirlpool refrig and it has a bad control board . This board is located behind the refrig , on the left side at the bottom , inside a plastic housing . This housing is held on by 2 screws at the bottom left . Remove the housing and the control board inside . Replace the board and reinstall the housing . It costs about $ 80.00 . When you go to get the part , take the complete model number with you so you get the correct board . This board controls the light for the refrig AND the lights for the control knobs PLUS other parts which work ok relating to the cooling .
Sep 23, 2010 | Refrigerators
Have a Honeywell House Humidifer - Control Malfunction?
get a humidity gauge from radio shack for about 20 bucks. thats the only way to tell. or pay a service compant tocome out for probaby a 100 bucks to tell you what the humidity level is in your home. id get the $20 one a the shack
Dec 02, 2009 | Honeywell Power Humidifier: Furnace...
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
14 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
