Question about MSI GX720-033US 17-Inch Notebook PC
Hello my msi gx720 will not open dvd but will play cd any solutions?
When I insert cd into drive the computer instantly recognises it. DVDs or other software like games it can not read. the drive whirrs a couple times then asks to insert a disk.
5 Suggested Answers
  • 57 Answers
SOURCE: When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Posted on Jun 15, 2009
Testimonial: "Brilliant. Thanks so much. It worked a treat. Much appreciated"
paand
  • 147 Answers
SOURCE: installing software with no cd/dvd rom drive
You can use usb pen drive or usb hard disk to transfer files.
Posted on Jul 08, 2009
  • 84 Answers
SOURCE: when insert msi utilities disc into d drive I get
try in another computer maybe is empty
Posted on Mar 07, 2010
  • 6771 Answers
SOURCE: Msi a6200 won't read ANY discs lately.....not sure what or where to start any info would help.
It seems like you have a hardware issue, clean lens with rubbing alcohol and a Q-Tip gently, allow several minutes to dry, if no change, remove screw from the bottom where the drive is and take it out, now reseat it back in place, if still the same go to www.ebay.com Type: make and model of laptop, refine search to cd/dvd driver.
Posted on May 11, 2012
My MATSHITA DVD-RAM UJ870QJ ATA will not recognise an audio cd
i tried this and it worked when nothing else would.
http://sites.google.com/site/matshdvdfix/
Feb 21, 2010 | Acer Computers & Internet
I have bought a Super slim external USB portable 24x CD-ROM for my Dell notebook. I can't get DVD's to play on it. The laptop recognises the removable device but there is no option to play the disc. Can...
CD ROM drive will play only 700 mb CD disks(normal CDs)...and not play DVD disks...u need DVD ROM drive to play DVDs....there is a big difference among both in it's function.
a DVD drive "may" play both DVDs and CDs....
but
a CD drive will "only" play CDs
Feb 18, 2010 | Computers & Internet
Not able to burn dvd
Some dvds have different dyes and as such some dvd rws wont recognise them, i had this problem with my new laptop and I only discovered it when i tried to burn back up discs. generally dvdr- are more suited for burning from your computer, you could try using differnt blank dvds AONE and RI-DISC are good discs, if you are unsure ask at your local pc shop ,if your in Glasgow Priceless computing offer good advice and carry a large selection of dvds, I would avoid the pound shop as the quality of their dvds is poor, should the problem persist take the dvdrw back to the shop where you bought it from, I hope that you are lucky.
Have you tried using MAGIC DVD RIPPER ? this is a program that allows you to copy dvds to your hard drive in dvd quality and you can then burn them to disc using nero, you get a free trial of this program from magicdvdripper, its good if you rent a dvd and want to keep a copy, anyway please let me know how you get on.
Best wishes.
james
Jul 11, 2009 | Computers & Internet
Cant get DVD's to play
Try cleaning off the laser of the dvd drive with a damp q-tip. This will make sure there is no specs of dust or dirt on the laser.
If it sill plays cd's but not dvd's then that means the laser is bad cause it takes more power from the laser to read dvds cause there is more information that needs to be verfied.
So if the laser is bad that means the drive you bought was defective. Try a bunch of different dvds to be sure you don't have any that are bad.
If your getting it with any dvd your putting in there then you know you need to get another drive.
May 31, 2009 | Dell Latitude C600 Notebook
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in CDR-zone.com (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
DVD player
this is dvd drive problem
clean your dvd lens and restart and check it
Oct 25, 2007 | Dell Inspiron 6400 Notebook
MSI GX720-033US 17-Inch Notebook PC  Logo
14 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
