Remote codes hello i have a digitech N287 urc and need code for palsonic led tv cheers
SOURCE: Need codes to program all for one remote
Had the same problem and stumbled on the code for the Proton tv, 10178. (We use a Comcast Cable remote) It works! For us at least... Good luck!
Posted on Feb 24, 2008
SOURCE: remote control codes
Hi
Yes, I did get the codes I needed by calling the company direct.
Thank you
Posted on Aug 04, 2008
free2rhyme
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
Posted on Mar 25, 2009
BElectric
  • 1140 Answers
SOURCE: i have a currys essentia
I'd like to be able to give a more positive answer but I don't think this combination of remote and TV will work together. One-for-All do not list codes for Curry's brand devices. These are simply 'badged' TVs from an often unknown manufacturer.
As there are no codes listed for your brand, identifying a code which will work is limited to trying to identify the original manufacturer of the TV and hoping that your TV shares common components with a TV that your remote does have codes for. There are too many codes in the remote to try to guess a code or to try them all using the manual code entry method.
Your best option is to try the Code Search:
1. Switch the TV on.
2. Press the "DVD" button on your One-for-All remote
3. Press and hold the "MAGIC" button on the remote until the red LED under the POWER key flashes once, then twice.
4. Enter 9 9 1 using the number keys on the One-for-All remote
The LED will blink twice again, indicating that the code search is active.
5. Press the "POWER" button on the One-for-All remote
6. Point the remote at your TV and press the "CH+" button slowly and repeatedly until your TV switches off.
7. As soon as (or if) your TV switches off, press the "MAGIC" button again to store the code.
8. Test the remote with the TV for the common functions, i.e. POWER, VOLUME and CHANNELS.
9. If the TV does not respond (or does not respond as you would expect), go back to step 1 and continue the code search . This does not restart the code search from the beginning, it simply picks up from the code that is currently set and continues through the code list.
Please note: There are hundreds of codes stored in the remote so it can sometimes take half an hour or more to search through them all.
Your TV is a DVD combi so this means the correct code should be stored in the code list for DVD players. However, as it is impossible to discover the true identity of your TV, it is also possible that there may be a code that will work with your TV in either the TV or VCR code list. You can try repeating the code search as above, but in step 2, press either the "TV" or "VCR" button instead to run through the codes for these device types.
It is also possible to control some TV/DVD combis by using two codes. Run through the code search in "TV" mode first. If you can find one that will operate the TV functions, store it, then run the code search again in "DVD" mode. You may then find a second code that will operate the common DVD functions, e.g. PLAY, STOP, PAUSE, etc. If this method works, you simply need to remember to press the "TV" or "DVD" button on the remote first - depending on which function you are trying to control.
There is a "pot-luck" element to getting any universal remote to work with any device. There are hundreds (maybe even thousands) of universal remotes and thousands of brand/model combinations of TV. This means there is an almost incalculable number of combinations of TV and universal remote and expecting there to be a code for every device is unrealistic. Unfortunately, this element of luck also increases for devices from a lesser known brand and even more so when the TV is newer than the remote.
Please try the code searches as detailed above. This can require a lot of patience. If you still can't get any response from the TV, then it's unlikely that your particular combination is one of those that will work. You would also be taking the same chance with any other universal remote, even if you bought a new one.
If you can't get any results from the code search, please post back for further assistance.
Regards,
BElectric
Posted on Dec 30, 2010
caroldon
  • 17130 Answers
SOURCE: i have a total control
Please check the codes in the links below;
http://www.xdiv.com/remotes/
http://www.hifi-remote.com/ofa/codes-tv.shtml
http://www.logitech.com/en-in/440/3898?selectedcrid=440&selectedcid=3898&WT.z_sp=Product&osid=&bit
Posted on May 12, 2011
Testimonial: "thanks a lot "
One for all URC-6230 / 6231 Universal Remote code for supersonic led tv
Hi Anonymous, The codes you're looking for ara
11125
12424
15322
21354
13135
22321
14421
11233
I found these codes on this web site, right side about half way down on page 58 ...CHEERS..
http://www.manualslib.com/manual/115210/One-For-All-Urc-6230.html?page=58#manual
Apr 02, 2016 | One For All Televison & Video
Tip
One For All URC-4021 Code Search
One For All URC-4021 Universal Remote Code Search
To program your One For All URC-4021 universal remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
___________________________________
One For All URC-4021 Manual
One For All URC-4021 Code List
One For All URC-4021 Code Entry
One For All URC-4021 Reassign Key
on May 30, 2010 | One For All URC-4021 Remote Control
Tip
One For All URC-3300 Code Search
One For All URC-3300 Universal Remote Code Search
To program your One For All URC-3300 universal remote control to operate your TV, the remote has a code search function.
I hope that helps.
One For All URC-3300 Manual
One For All URC-3300 Code List
One For All URC-3300 Code Entry
One For All URC-3300 Reassign Key
on May 30, 2010 | One For All URC-3300 Remote Control
I need sansai urc-l969 universal remote palsonic tv code
Codes to check with Palsonic are: 0152 0161 0166 0207 0249. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 11, 2014 | Televison & Video
Digitech N287 Remote control A/C
I want to buy a digitech N287 air conditioner remote. where do you buy them
Sep 03, 2013 | Music
Tip
One For All URC-4605 Code Search
One For All URC-4605 Universal Remote Code Search
To program your One For All URC-4605 universal remote control to operate your TV, the remote has a code search function.
I hope that helps.
One For All URC-4605 Manual
One For All URC-4605 Code List
One For All URC-4605 Code Entry
One For All URC-4605 Reassign Key
on May 30, 2010 | One For All URC-4605 Remote Control
Lost manual need set up instructions and code for Panasonic TV
Hello;
The manual for your URC-3021 is located at
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021 .
Pgs. 8-10 cover device programming, code searches, code checks and, according to Pg. 19, the codes for a Panasonic TV are: 0051, 0250, 0650
Cheers.
Mar 19, 2011 | One For All URC-3021 Remote Control
Code for remote
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
Hope that helps.
Dec 08, 2009 | One For All URC-3021 Remote Control
Need 4 digit code for my tv
Here is the code
To download the manuals just click the link
http://www.rockabilly.net/files/manuals/URC-7540.pdf
I hope it helps!!!
Dec 04, 2008 | Televison & Video
Code for Palsonic 6830TG TV
if the volume down ts working then that means the remote is working if the volume + does not work and the channel + then they need to be cleaned with isopropyl alcohol using a cotton swab, that means you will have to open up the remote control
May 27, 2008 | One For All URC 7740 Remote Control
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
