Question about Invacare Pronto M51 Power Wheelchair
Wiring diagram for pronto m51 joy stick
I need to know how to wire the on/off switch and also the speed control switch on a pronto m51 joy skick
  • 175 Answers
SOURCE: won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
http://www.invacare.com/doc_files/1125085.pdf
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: Circuit Breaker on Pronto m51
Here's the manual. Locate battery cables follow them to the motor and Joystick. you'll see the reset button
Posted on Sep 02, 2009
  • 17 Answers
SOURCE: speed control knob has come off
you need Invacare part # 1040225, cost about $6.00. Call these people 866-722-4581
Posted on Sep 22, 2009
Testimonial: "I looked on the internet for this part for HOURS without success. The "FixYa" expert found the model number needed and the phone # to order. Thanks!! "
  • 692 Answers
SOURCE: What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Posted on Sep 08, 2010
wcdoc1953
  • 278 Answers
SOURCE: I NEED A WIRING SCENATIC FOR AN INVACARE PRONTO m6
I assume you need a wiring schematic for an M61. The circuit board schematics are proprietary and not available. The component schematics and interconnects for switches and wiring harnesses are available, as are the parts diagrams and drawings. Please clarify your specific need and issue.
Posted on Oct 24, 2010
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
My m51 flashes 11 times on joy stick what is that
The diagnostic code would indicate a bad control box. It could also be too low a voltage from the batteries or a bad or broken wire or connector between the joystick and the control box. Chair will need a technician from a good dealer to help out if battery's and wiring are good.
Sep 09, 2015 | Invacare Pronto M51 Power Wheelchair
A lot of play in joystick, Of my Pronto M51 powerchair
your joystick needs reprogramming or replacing. A descent mobility shop will normally be happy to check it for you, some may offer to reprogramme free hoping to get your future custom, reprogramming is very easy and only takes a few mins, if the joy stick is damaged and needs replacing, it may be cheaper for you to try and get a second hand controller from some were like eBay, I managed to get a spare controller for my chair (jazzy 1120 of eBay for 7.50 UK pounds. but it is down to luck what is being listed, if you are handy with a screw driver see if you can get just the joy stick, and replace just that, but be careful not damage any thing else in the controller when you take out and replace the joy stick.
If this helps, please click on the "YES" button.
Sep 18, 2014 | Health & Beauty
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
When operating the Pronto M51 power wheelchair with the joystick, it will only move forward and backward. It will not turn. What do you think the problem is?
I would suggest that the micro switches that the joy stick operate have become faulty or got out of adjustment. contact the makers service agent to fix the problem
Sep 23, 2013 | Invacare Pronto M51 Power Wheelchair
Will only work at a slow speed speed con worked fine the next day dead slow is al it will do
have a dealer tech check it with a programer and he will tell u what the problem is by checking the error log could be just a joy stick needs to be reset or the control box in the rear,make sure your insurance will help with repair
Aug 31, 2013 | Invacare Supply Group Invacare Pronto M51...
Wiring diagram
I need a wiring digram for the M9 prontopowerchai
Aug 19, 2012 | Invacare Pronto M51 Power Wheelchair
Speed control knob has come off
Sep 21, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
43 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
