Question about Western Digital Caviar WD1200BB 120 GB Hard Drive
Where can I find instructions on how to install a wd1200bb as 2nd drive
  • 30 Answers
When it comes to data recovery one of the most common problems Western Digital(WD) hard drives experience is burnt cuircuit board(PCB). WD drives are very vulnerable to overheating, power surges and streaks. Quite often bad power supply unit combined with power streak is usually enough to fry spindle driver chip on the electronics and make the data inaccessible. Should this occur the computer would reboot or shut down completely, you would normally notice acrid smell of smoke coming from your PC and when powered on the drive would not spin up at all and appear to be completely dead.
where can I find instructions on how to install a - burnt_chip.jpgIf this is the case you can try to swap PCB from another WD drive of the same model but your chances of success are close to zero, especially on newer hard drives. The problem is that logic board on modern hard drive is adapted to the head disk assembly it was manufactured with. In our lab we use specialized software and hardware to rebuild these parameters or transfer them from fried board to make donor PCB fully compatible with damaged drive.
All Western Digital hard drives are also well-known for their firmware problems.
Firmware of the drive is not located on the logic board as most people think. Main part of firmware is stored on the platters in so-called Service Area. Service Area occupies the negative cylinders of the surface and contains a number of firmware modules. If one of the modules gets corrupted the hard drive fails to initialize correctly and stops working making the data inaccessible. In such case the drive usually spins up fine, it doesn't click but has one of the following symptoms:
  • it is not found in BIOS at all
  • identifies with its factory alias(for example WDC ROM MODEL-MAMMOTH---,WDC ROM MODEL-HAWK---),
  • shows up with wrong S/N (for example WDC-ROM SN# XYZ---) or capacity,
  • identifies fine but fails to read any data or boot up operating system giving I/O device errors whenever you try to access LBA sectors.
If you attempt to boot up from such drive or read any data from it you would get "Primary Master Hard Disk Fail" or "No operating system found" or "USB Device malfunctioned" error or "S.M.A.R.T. Capable But Command Failed" or "Disk boot failure. Insert system disk and press enter", "Hard drive not recognized", "Drive Mount Failure" or some other hard drive boot error. At the moment it is not possible to fix this kind of problem at home. It is quite a complicated job and requires use of specialized expensive equipment and deep knowledge of hard drive design and data recovery technology to repair the firmware. Luckily, it is not usually necessary to open the HDD in clean room and order donor drives, so chances of successful data retrieval are close to 100%.
Another quite common symptom Western Digital drives experience is clicking/knocking/clunking/sweeping noise.
heads_ok.jpgThe drive spins up, and and the heads start clicking with a constant or intermittent sound while unsuccessfully trying to locate firmware zone: , , , . Usually this is a sign of damaged or crashed heads and it means the drive needs to be opened in a class 100 clean room environment in order to replace head stack assembly. Don't try to open the drive by yourself - you could damage the platters making your data unrecoverable.
Western Digital drives also have common problem with spindle seizure. Usually this occurs after a fall and the drive either doesn't spin up at all with a siren sound: or starts up with loud noise unable to gain enough rotational speed: . Data recovery in such case involves removing platters from the hard drive in clean room environment and putting them into matching donor. This complex and precise procedure requires a lot of experience and use of specialized hardware to maintain platters in perfect alignment.
WD laptop drives(Scorpio, UE,VE series) share some typical 2.5 inch HDD problems. One of them is heads sticktiwhere can I find instructions on how to install a - headstick2.jpgter surface.
headstick2.jpgHeads are normally parked on the parking ramp outside of the platters, but sometimes after a fall or abnormal termination they fail to return to their regular parking position and are left on the surface. Immediately after the motor stops spinning they stick to the ideally smooth surface and it becomes impossible to free them without proper tools and experience. Don't attempt to open the drive by yourself - you will damage the platters and this will make your data unrecoverable. There is one more problem that is typical for all Western Digital drives: bad sectors. After some period of time magnetic media the platters are covered with starts to degrade and magnetic domains can't turn in the desired direction by writing element of the head. This is how bad sectors appear.
When the drive starts reading data from such unreadable bad sector it could start freezing, scratching and sometimes even clicking: . Usually on boot up you would get "SMART failure predicted" or some other SMART-related error. All this leads to further damage to the surface, heads and causes more data loss. Any further reading attempts would just add up to the problems and could make your data unrecoverable. In our lab we use special imaging hardware tools that are capable of reading raw sector data ignoring low level checksum check. That's usually the only way to retrieve as much files as possible from such sectors.
If you experience any of the symptoms described above with your Western Digital WD1200BB-00CAA0 please feel free to contact us to get upfront quote on data recovery from your failed drive.
Posted on May 19, 2009
  • Rhegie Cañete
    Rhegie Cañete May 19, 2009
    If
    Firmware
    If
    The
    unrecoverable.
    WD laptop drives(Scorpio, UE,VE series) share some typical 2.5 inch HDD problems. One of them is heads sticktion to the platter surface.
    Heads
    appear.
Can't download the device driver
What operating system?
What enclosure?
USB? Fire wire? E-SATA?
Windows should see this device and have the driver built in?
What error codes? messages?
Mar 26, 2014 | Western Digital Caviar WD1200BB 120 GB...
Lba 234441648
Each LBA unit is 512 bytes.
So, 234441648 LBA units is about 120 gigabytes.
Jan 29, 2014 | Western Digital Caviar WD1200BB 120 GB...
PC w/ Vista. Can add 2nd drive with Win 7 and transfer all data & programs?
Try and get a disc clone software and use this instead.
Second, you need to set the jumper on the hard discs in order to configure your drives as either Master or Slave too.
Oct 07, 2017 | Computers & Internet
External hard drive is work properly but does not show on "my computer"
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Western Digital Caviar WD1200BB 120 GB...
Where is the windows operating system physically loated on the computer
The default path for the Windows operating system is C:\Windows or C:\WinNT
However, this could be sometimes different, especially for computers with multiple operating systems installed.
Anyway, you can find out the path where the Windows operating system is installed by opening the Start menu, clicking Run, & then typing "%systemroot%" (without the double quotes) in the text box, then pressing Enter. This will get you directly to where the Windows operating system is installed.
Jan 12, 2010 | Western Digital Caviar WD1200BB 120 GB...
I want to link 2 installed hard drives on my laptop
You cant link them together as they are logical DOS drives.
Apr 10, 2009 | HP Pavilion dv9000z Notebook
Hard disk drive in slave position
Check your jumper settings... Following link is for your hard disk ST3160021A instructions.
http://www.seagate.com/images/support/en/us/cuda_sata_block.gif
Good Luck :)
Feb 21, 2009 | ASUS P5GD1-VM Motherboard
What 2nd "Slave" hard drive should I buy to match my "Master"?
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Dec 29, 2008 | Mobile Rack - 3.5 Inch Hot-swappable...
DVD hardrive problem
Do you check the setting of your hard drive? It seems that you have already another hard drive (HD) install which is working already were your operating system install. Try to put the 2nd HD setting in slave position. Follow instruction that is written at the back of HD. Your computer should read the 2nd HD as slave and will see it as drive: F or G and so on.
Jan 11, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Western Digital Caviar WD1200BB 120 GB Hard Drive Logo
824 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
