Question about Canon Office Equipment & Supplies
Spot print some place as the row line black line and one side frees and one side not frees as the column line
osiriscompu
  • 16 Answers
SOURCE: Spots/Lines on the prints
Take out the drum cartridge (piece with the long green arm) and look down inside the printer for any toner that may be leaking on your pages.
So I understand correctly, you were seeing different color toner on the cyan and yellow rollers?. If so gently clean that side of the roller off. Rotate the white gear on the right side of the toner cartridge back towards you and see if the correct color comes back on the roller. If you were seeing grooves on the roller then they will have to be replaced.
Put the toner cartridges back in and run color calibration.
Press menu/select. Right arrow key until you get to engine. Press select. Left arrow key until you get to service.
Press select. Right arrow key until you get to color calibration.
Press select.
Any other information would be helpful.
Posted on Jul 19, 2008
  • 21 Answers
SOURCE: black line on left side of paper
It sounds like a cartridge issue. Try changing the cartridge.
Posted on May 26, 2009
  • 990 Answers
SOURCE: Black spots and lines on papper
Hello sir; Only thing you need to do is change a drum cartridge.
Posted on Jun 03, 2009
secretgeek50
  • 57 Answers
SOURCE: faded streaks for only blak color on Ricoh 3500N laser printer
Your toner cartridge is probably getting low. Toner is actually a powder, and it can get settled during shipments, bringing it home, etc etc. Take out the black toner and give it a gentle side-to-side shake a few times and pop it back in.
That should help.
Posted on Apr 28, 2010
  • 670 Answers
SOURCE: i have vertical lines that
If your printer prints with faded bands similar to this:slamfix_29.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Posted on Feb 07, 2011
Cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
Aug 14, 2013 | Microsoft Office Computers & Internet
Tip
Deleting Rows & Columns from the table
You can also remove columns or rows from the table. Once a row or column is deleted, it can be undeleted by using Undo command. You can delete the columns or rows or cells by using one of the following ways.
By Table Menu
To delete a row or column by Table menu, follow these steps.
  • Place the insertion point in the column or row that is to be deleted.
  • Click Table menu and then select "Delete" from Table menu, a submenu of Delete is displayed.
  • Select Columns or Rows or Cells command to delete the selected element (column or row or cell) from the table.
By Popup Menu
To delete a row or column by popup menu, follow these steps.
  • Select the column's you want to delete.
  • Right click the mouse, a popup menu is displayed.
  • Select "Delete Columns" command, the selected columns will be deleted.
OR
  • Select "Delete Cells" command, "Delete Cells" dialog box is appeared.
  • Select "Delete entire row" to delete a row or select "Delete entire column" to delete a column etc. from the dialog box and click "Ok" button.
on Jan 29, 2010 | Computers & Internet
Lexmark t-620 print spots
That usually indicates a worn heat roller in the fuser assembly. You can get a fuser from Amazon or other online site. They are user replaceable and run about $80-100. Do a search for T620 fuser and you will find them. Part number 99a2402 What happens is the Teflon coating on the fuser wears down which allows the toner to stick where is should not stick so it gets deposited on the paper in other locations and leaves spots.
Apr 18, 2013 | Lexmark Office Equipment & Supplies
My color black does not print at times
Hi mserio007,
Please perform a deep cleaning.
1. Press the button on the printers operation panel.
2. Press the left [] arrow buttons to select [MAINTENANCE].
3. Press the button.
4. Press [] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
5. Press .
6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If this does not work, then It seem the contacts on the print head are damaged and you have to replace the print head to resolve the issue. But before that you can follow the steps below to remove the print head and then cleaning the copper contacts on them with a cotton swab dampened in distilled water until they are clean after drying them check the issue if the problem persist then replace the print head to resolve the issue.
1. Make sure the power is turned on.
2. Press [Open] and lift up the scanning unit. The print head holder automatically moves to the center of the machine.
CAUTION:
Do not try to manually move or stop the print head holder.
Do not touch any metal parts.
Press on the tab to release the ink tank, then remove it from its slot. Repeat this process until all ink tanks have been removed from print head.
3. Lift up the lock lever and take out the print head.
4. Reinsert the print head.
5. Insert the ink tank into the empty slot on the print head. Press down gently on the top of the tank until an audible click is heard. Make sure the ink tank is inserted into the correct color slot.
6. Close the scanning unit until it locks into place.
7. When the LCD displays [ALIGN PRINT HEAD], press on the operator panel. The machine will print a horizontal line pattern, and the LCD will display [CHANGE H VALUE] on the top row and [A 0] at the bottom row.
(A): Column A
(0): Value for Column A
8. In column A on the printout, note which box has the most solid image. Note the value next to this box and use [Left cursor] or [Right cursor] on the operator panel to enter it then press .
9. Repeat step 9 for columns B to K.
10. When values for all columns have been entered and the LCD displays [PRINT VERT. PATTERN?] on the top row and [YES=(*) NO=(#)], press [#] to return to standby mode.
Hope it helps.
Thank you for using FixYa.
Aug 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
My printer will not print. I recently changed ink cartridges and I'm getting a message suggesting that I realign something. How do I do that?
Most all-in-ones require you to scan an alignment sheet after changing the ink. Make sure the printer is on. Press Menu then use the up and down arrows to navigate to Maintenance. Click OK. Navigate to Auto Head Align and press OK. Select Yes and press OK. Load a sheet of Letter or A4 sized plain white paper in the rear tray, follow the on-screen directions. Open the output tray gently and the output tray extension. Press OK. When the page prints out, do not touch the printed sections. You should see a set of broken lines on the page, among other printing. The first section of columns will have 2 black, 1 blue and 3 black. The next row has 4 columns (blue and pink (to my eye)); the final row is 3 blue and 3 pink. If this prints okay, then select Yes and press OK. Next place the printed page face down on the glass of the scanner unit so that the black triangle at the top left of the page is in the left back corner of the glass. (The triangle is an alignment mark and lines up with the alignment mark on the edge of the scanner unit.) Close the document cover and press OK. The sheet will be scanned and the print heads will be adjusted. Do not open the document cover or move the sheet until the unit has completed the adjustment. Afterwards you can discard the sheet.
If the unit fails to adjust the print head, it will indicate this in the LCD screen. In that case, try manually adjusting the print head from the Canon Toolbox on your computer. If you can't get the printhead to align properly manually, the unit may need service.
For pictures, see the manual or support for the all-in-one here: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp490#ServiceAndSupport . If you use the Support option, search for align print head.
I hope this helps.
Mar 16, 2011 | Canon MP490 InkJet Printer
I can not draw a table in microsoft word
hi ermelitacapa,
To create a table in Microsoft Word please do the following:
1. Go to the Table menu and select 'Insert Table'. The Insert Table window will open.
2. Select the number of rows and columns you want in your table.
3. Select the column width (up to 22 inches) or choose 'Auto' to have the column with adjust automatically, making the table extend across the width of the page.
4. Select the AutoFormat button to select one of Word's pre-formatted table styles. The Table AutoFormat window opens.
5. Click one of the styles in the Formats box in the upper left side of the window.
6. Preview each format, after selecting it, in the Preview box in the upper right side of window.
7. To customize a pre-selected format, select or de-select the borders, shading, font, color, heading rows, first column, last row and last column boxes.
8. Select AutoFit, and Word will automatically fit the table to your page.
(To manually change the width of a table or column after you have created it, use the mouse to place the pointer over the vertical line you want to move. When the pointer turns into a double-headed arrow, drag the line to the position you want it in the table.)'
I hope this helps!
** If you find this information helpful please leave feedback to help us help others **
Feb 24, 2011 | Microsoft Windows 7 Home Premium 64BIT...
If I have a multi-row s/s that has multiple pages, how do I get the row title for columns to appear on each page?
Hi, I believe you're asking about 'freezing panes'...
In Microsoft Excel 2007:
  1. Select the place on the spreadsheet where you want the row titles to appear
  2. Click on the View tab
  3. Click on Freeze Panes button
  4. Select Freeze Panes
Or, you could be asking about defining print rows to appear at the top of each page:
  1. Select the Page Layout tab
  2. Click Print Titles
  3. Enter the Rows to Repeat at Top (e.g., 1:3 for the first 3 rows)
Hope that helps!
Feb 01, 2011 | Microsoft Excel for PC
Faded streaks for only blak color on Ricoh 3500N laser printer
That should help.
Apr 28, 2010 | Ricoh Aficio CL3500N Laser Printer
I had a vertical line on my laptop screen
A line on a LCD screen (like a laptop) is caused by a faulty power connection in the screen.
Usually a entire row or column will not activate causing a black line to show. When you closed your laptop, the screen is powered down. When you opened it back up, the screen would be reinitialized and it appears that you lucked out on your issue.
When a row or column fails it is usually a permament failure that can only be fixed by a monitor technician or a screen replacement.
A similar failure can happen that causes black dots to show on the screen. These are burnt out junctions where the rows and columns meet together. The dot is commonly called a pixel.
Jan 21, 2010 | Compaq Presario M2000 Notebook
Black line (strip of pixels not working) horizontal across screen
If a whole line of pixels is dark, you've got a bad transistor in what's called a "Passive Matrix" display. For your future purchasing decisions, while an "Active Matrix" display costs a little more, it has individual transistors for each pixel, rather than one per row and column, so when a transistor goes bad, it only turns one pixel black rather than a whole row or column.
Sep 12, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
12 people viewed this question
old marine
old marine
