2004 Toshiba TV 32A41 problem
TV has a 1 1/2inch horizontal bar that distorts the picture at the top of the TV screen.  Could the vertical hold be out of adjustment?  If so, how does one adjust the vertical hold?
The problem started after a power outage;  the cable repairman says it is not a cable problem (another TV set in the living room was not affected). Could it be another problem?
  • zeller2121 Oct 25, 2007
    October 23, 2007 comment.  2004 Toshiba Model  is 32A14, not 32A41.
  • 105 Answers
To me its sound like your on the right track. there isnt a physical vertical hold adjustment. more than likely the vertical hold ic has failed. send me your email addy to and i will be more than glad to email you a service manual
Posted on Oct 25, 2007
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ... > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from
Jan 05, 2016 | Samsung Televison & Video
I have a Sony KDLW3000, the picture has colored vertical lines on the whole screen,
The Tcon board is usually at fault with that symptom. You can get a replacement Tcon from
Apr 01, 2012 | Sony KDL Televison & Video
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
There are about 10-15 small lines on the top of the screen that go horizontally all the way across. These lines distort the picture up there and it is very distracting...any ideas?
The problem is in the vertical section of the TV. Usually one of the electrolytic caps has gone bad. Easy job if youre experienced with board level component replacement.
A shop should charge under $100 to fix.
Nov 23, 2009 | Toshiba 27AF53 27" TV
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Is my picture tube going?
Hi there yes this is a common problem with old tube tv's and yes eventually stuff seems to break down there is not alot you can really do about it to be honest suggestion is that this is lifes way of saying upgrade ...this tv has done well ....if your looking to upgrade i would suggest going to a Samsung LA26C450 as a replacement television or if you are not so much a fan then a KLV26BX300 as a new option ,
Nov 04, 2008 | Samsung TXK2754 27" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Diagonal distorted picture
convergance amp ic bad
Dec 14, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
371 people viewed this question
Top Televison & Video Experts
