Question about Samsung Computers & Internet
Samsung Model LN55B650T1F not picking up wifi from linksys WRT54g router
Trying to get Samsung tv to recognize wifi from Linksys router and bring up TV's screen to enter WEP key to access wifi
3 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: I dont know how to change the SSID Name and WEP Key.
You have to change it in the printer settings, not in the router! Otherwise you'll lose connectivity in all the other computers that use this router.
The SSID is the name you gave to your wireless network, and the WEP key is the password you set for your wireless connection.
Posted on Oct 28, 2009
Testimonial: "Thank you for your help. Almost made a problem a bigger problem. "
  • 247 Answers
SOURCE: wep key for Linksys
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option (you) can copy the wep key from this field if you want to use the old one or just modify it for your new wep key8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Posted on Dec 26, 2011
Can samsung 6 series 6600 smart tv wifi run on linksys broadband router
It should provided the TV is configured correctly with the Linksys wireless settings.
Aug 21, 2012 | Linksys Wireless-G WRT54G Router
Hi, I have a Sony Ericsson Xperia Neo, and every time I want to connect with my WIFI the router reboots. This issue only happens with my Sony Ericsson Xperia Neo, other phones and devices work just fine....
Just had same problems with my brand new Xperia Mini Pro and old WRT54G ver 5. Every time I connected with WiFi the router restarted (once it returned to factory settings). I updated the router firmware to latest version (1.00.6 to 1.02.8) and after this it works fine.
Best Regards
Peder
Sep 17, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54G which I have hooked up to my older Dell computer successfully. The signal is excellentfor this one, called "Bob" for clarity. I am trying to hook up to "Bob"...
Sounds like you may be experiencing excessive interference in the WIFI space. Try setting the linksys router to use a different wireless frequency. (normally the available ones are 1 - 11).
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
How do I link my Linksys wireless router to my Samsung tv so I can have internet on my tv or is this possible?
check your Samsung manual it will show exactly how to set your Tv to the router.
http://www.usersmanualguide.com/samsung/tv__lcd/la15s51b
Aug 07, 2010 | Linksys Wireless-G WRT54G Router
My linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Wireless conectivity
I had the same problem with this model. I was trying everything including resetting the Linksys to a factory default and loading latest firmware, nothing helped. I had to replace the Linksys to fix the problem. I think your radio on the Linksys is not working even you have a signal showing on your laptop.
Regards
May 27, 2008 | Linksys Wireless-G WRT54G Router
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
The Computer doesn't recognize the Router (And Yes. the wireless switch is turned on)
DON'T use the software.
Are you trying to connect by way of ethernet cable or wireless?
Either way you do it, you do NOT need that crap software. 90% of the time, that software interferes with everything. Up to AND INCLUDING preventing your system from connecting to the router.
Before you can get any help with this, you will need to give us more information about your setup.
NOTE: We CAN NOT POSSIBLY figure out all of the variables if you do not give them to us. So don't go marking my post as "Thanks for trying" just because your problem is not solved in the first post.
Instead, if you want answers, you're going to have to be more specific.
I see a Linksys WRT54G wireless router. Is there a version number on there?
Example: WRT54G v3 (Mine.)
You're also going to have to tell us more about your computer. Is it Windows XP? Service Pack 1/2? Windows Vista? Linux even? (Give model numbers if it's a pre-built system from an OEM manufacturer such as HP, Dell, etc.)
Then there's the internet connection. Cable internet? DSL? Satellite? Give us MODEL NUMBERS of the equipment they have issued to you for your internet connection.
Then tell us how you have things connected. Wireless? Ethernet cable? What is connected to what?
See what I mean?
FULL details bring quicker resolution of your problem. I will be monitoring this post as you seem capable of providing this information to us. When I see more complete information, I will help you further from there.
Thanks. :)
Cyryl
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
18 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
