Question about Pinnacle Computers & Internet
Installshield error error 1330
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Errorvalue c000009c disk type 5 i had flexerasoftware install shield 2010.exe from saturn.installshield.com i down loaded it but my computer won't let me use it can you help me i hope so. mary ...
Looks like a dll registration failure and/ or a Permission problem.
  • Please go to your Event Viewer. (Start -> Run -> Type in Eventvwr.msc and hit enter)
  • Go to Application category
  • Check for the Errors (Red X) and read the description and make sure that program is the one returned the error
  • Post here the errors with details.
  • You can use this Link to browse or ask for assistance from InstallShield
Thanks and have a good day! -Lasitha
Jul 17, 2010 | Computers & Internet
Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Jun 05, 2010 | Microsoft Windows Vista Home Basic for PC
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
Where is the serial numbe ron the box?
Here are the bundled keys for Adobe Photoshop CS4:
1330-1473-8986-0777-1066-0841
1330-1149-8680-8826-2079-9036
1330-1193-3970-6999-1448-5950
1330-1258-6735-8548-6856-6068
1330-1179-3258-0293-7610-2519
1330-1409-6829-9786-8399-8047
1330-1680-7727-3628-3873-7625
1330-1321-2573-8243-5596-2306
1330-1836-2639-4367-7210-1791
1330-1070-9423-5792-3477-3630
1330-1936-7146-7221-5976-4469
1330-1615-1299-3019-7242-1546
1330-1043-6516-1505-2924-4405
1330-1614-6908-3941-2384-0909
1330-1443-6987-9307-7405-4256
1330-1252-9271-7220-3985-4522
1330-1692-9040-8033-4000-5264
1330-1364-9655-9747-2144-4369
1330-1011-7905-1557-1505-9767
1330-1266-1613-1692-9307-6182
1330-1149-8680-8848-6856-6068
1330-1179-3258-0293-726-2079-9036
1330-1258-6735-85610-2519
Just select one of them.
Aug 27, 2009 | Adobe Photoshop CS4 Extended Full Version...
Installshield 3 Help (maybe)
I didn't get a solution but the project was dropped. I don't have to do this install.
Sep 19, 2008 | InstallShield Update Service Version 3
Camera wont download the photos.
http://digiblue.com/customer-service/downloads/drivers/SQ905C_DSC_Drive_XP_Vista_DigitalBlue_V2.005_2007MAY24.exe
if you are using windows vista use the following above link to download the new driver.
1) Please install the Disney Pix 2 software and the Disney Pix Micro Downloader to your computer via the software CD that came with the Disney Pix Micro
2) Please double-click on the "Setup" to begin the install of the Pix Micro drivers. The User Account Control will appear warning you that a program is trying to run. Please click "Allow".
3) Complete the install of the driver by following the prompts.
4) After the install completes, you are prompted to restart the computer. Please select "Restart now" and then click "Finish".
5) You can now delete the Setup program from your computer
6) Connect your Disney Pix Micro to the computer and wait for the device to install.
7) Double-Click on the Downloader shortcut to open the downloader
Now the Pix Micro Downloader is open with the correct privileges and the Pix Micro camera is connected. If you click the "Download" button. A dialog box appears saying "Pixel Up".
Please click the "OK" button and the download will complete successfully. The images can even be deleted via the downloader after the images are downloaded. Although, every time you open the downloader, you must run it as an administrator and every time you download, the "Pixel Up" box will appear.
If you are having a problem installing a product that uses InstallShield as their installation tool, and the steps below do not resolve your issue, you will need to contact the vendor of the software, as we cannot provide further support. Your vendor, who used InstallShield as an installation tool, created the product that you are trying to install. It is very likely that the error you are getting is related to how the vendor used our product and only the vendor would know which InstallShield product they used, which version and how they programmed it. Thank you for your understanding and patience.
This article applies to the following errors when trying to install an application that uses InstallShield:
Error extracting support files
Error installing Ikernel.exe (0x any number)
Access is denied
Error loading Type Library/DLL
Discussion
Detect Version
Different troubleshooting steps are necessary for different version of InstallShield. To check the version of InstallShield Professional that was used to create the setup, take the following steps:
1.Right-click on the setup.exe
2.Select "Properties".
3.In the Properties dialog, select the tab labeled "Version".
4.Near the top there will be a filed labeled "File Version". The number specified here will tell you approximately what version of InstallShield was used to create this install.
InstallShield 5.x and 3.x
If the version of InstallShield is less than 6.00, see article Q100198, HOWTO: Eliminating General Setup Initialization Errors.
InstallShield 6.x
If the version is 6.00 or greater, continue with the following steps.
Setup initialization errors can be caused by a number of factors. This is a non-exhaustive list of possible resolutions:
1.Insufficient permissions on the machine. If you are using a Windows NT or a Windows 2000 machine, you need to have administrative permissions to run an InstallShield Professional 6.x setup. Make sure you have the correct permissions.
2.If you just ran an InstallShield setup, the engine takes a few seconds at the end of the installation to clean up. During this time Ikernel.exe (the engine file) is running in memory from a previous process. That is why you are not allowed to launch another setup. Waiting a few seconds and running the setup again should resolve this.
3.Check and make sure Ikernel.exe is not in memory. If it is, and no setup is running at the time, end that task and restart the system.
4.Clean out the Temp directory.
5.Delete the Program Files\Common Files\InstallShield\Engine folder and then rerun the setup.
6.Reinstalling Internet Explorer (IE) 5.x can also repair a number of corrupted/missing core Windows files from your machine, so reinstalling IE 5.x and the NT service pack is also suggested.
7.Another possibility is that you do not have sufficient COM permissions. For information on how to troubleshoot this, see article Q104986, INFO: Initialization Error Troubleshooting.
8.The other potential cause is a missing Stdole.tlb file. This is a core Windows file and should exist on your machine. Make sure that if you get this file from another machine, the machine is running the same operation system as the machine you are trying to run the setup on.
9.If you are trying to install to a Windows 98 machine, download and run Dcom98.exe from the following site: http://www.microsoft.com/com/dcom/dcom98/download.asp.
10.Make sure that you are using the latest version of the InstallShield engine. To install the latest engine see article Q105097, INFO: Install the Latest Version of Ikernel.exe
Aug 01, 2008 | Disney Pix Micro Digital Camera
DOWNLOADING ITUNES
Update to the Latest InstallShield Installation Engineshttp://consumer.installshield.com/kb.asp?id=Q108322
Jan 05, 2008 | Microsoft Windows XP Home Edition
Error Containing "0x123454" when installing software
Any error code beginning with "0x" is related to a problem with incompatibilities with the InstallShield program which is used to install all of the components. To fix this find the "InstallShield" folder on the computer (the location varies by computer OS, but is generally located in "c:\Program Files\Common Files\") and move the contents to a new folder on the desktop of the compter. If everything works well you can discard the new folder (and the old InstallShield contents). Run the Nikon installer again and it will install properly.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Computers & Internet Logo
19 people viewed this question
Top Pinnacle Computers & Internet Experts
Alun Cox
 Ian Kayhan
Ian Kayhan
Josh Levin
Josh Levin
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
