Question about Sony STR-DE1075 Receiver
Center channel my center speaker cuts in and out intermitently. I can hear ther relay click when this happens
  • Anonymous Nov 27, 2008
    not sure if i just loose the centre speaker,but i do loose volume and the sound seems to come through different speakers and i do here the click comming from the receiver
SOURCE: Sony STR-DE845 center channel cut out, receiver clicks
balls
Posted on Dec 20, 2007
SOURCE: Speaker Channels? STR-DE505
Hi There,
Maybe can clarify the reasons you have different output configurations.
I worked for Dolby in London for ten years and cinema processing was an area close to me.
To cut a long story short;
The number of factors and different combinations possible for a fully equipped cinema offering Dolby and / or other protocols to the guest is large to say the least even within the Dolby formats.
For Sony to try to offer a range of home units (recievers or tuner/amps/decoders in this case) was to say the least ambitious .but hey!..........who else can give the public what they think they need.,,,good old Sony
I have looked at this unit and it seems the "amplifier section" is used for various configourations
and power output ratings vary depending on the configuration you choose.
Stereo 2 ch L+R is 2 x 75w
Surround requires more channels (centre and mono rear) and of course new signal routing to and from these blocks which of course will draw from the modest power supply.
So 4 channel surround will deliver 4 x 50w.
etc. etc.............what you hear are the relays which are reconfiguring and re - routing the signals.
Basically you cant have all the sections working all the time due to cost /design restraints
So speakers A OR B can be used but not BOTH when in surround mode....where the centre and surround are needed. .you cant have A and B at any time....push both buttons an NEITHER will work ....release one button and there you go.............it saves "letting the smoke out of the box".........which you should never do...........cos they never work without it. :)
Sorry for boring you ...............but I think you will find the unit is working just fine.............you could read the manual but that's not too informative.
Right...off to get a life now
Nik
Posted on Nov 22, 2008
SOURCE: Center channel cuts out during movie, a click
Check the solution posted by "bikes" at http://www.fixya.com/support/t102695-sony_str_de845_center_channel_cut_out
Posted on Dec 25, 2009
SOURCE: center speaker cuts out.
There's some bad solderings under the 3 blue relays on the mainbord
So grab your best scerwdriver ;-)
Posted on Jan 12, 2010
rommelalilin
  • 2178 Answers
SOURCE: Cannot hear rear channel on Sony STR-DTE325
First off, you want to correctly isolate what or which channels are/is bad. Use one good known speaker. Connect that speaker, one channel at a time, and test that channel with a fixed volume level (don't adjust the volume when you check each channel). Isolate the low level channels and make note of it. Note: each channel has their own amplifier. Once you've isolated the bad channels, take it to a repair shop and tell them the bad channels. They will then locate the circuit and narrow down the search to fine the problem - it's usually a bad solder connection. If it blows fuses - more likely a shorted transistor. In your case it's a bad solder connection.
Posted on Dec 22, 2010
When we watch football, we can't hear the refs on the field. Also during halftime we can't hear the music. Some random things get cut out.
do you have a center channel speaker hooked up? Most voices come through the center channel. I would imagine the surround processor would put the refs on the center channel.
Jan 06, 2013 | Sony STRDH830 7.1 Channel 3D AV Receiver
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
Avr-f100 surround left and centre working intermittently can anyone help.
The same happens with my POA-F100, but only the center channel is affected (apparently the most important for movie/tv).
Seems to be a malfunction of the speaker relay (you can hear it clicking some seconds after power on). In my case a (sometimes pretty rude) hit on the side of the compartment with the flat hand helps, so the contact just mechanically hangs.
If I find the time I will open up the compartment to see if I can get a fitting spare part relay and solder it in (so I don't have to beat my Denon Setup any more ;-)
Jan 03, 2011 | Denon Audio Players & Recorders
No audio in channell a out put
Check your connectons on the back of the receiver as well as thoes to the speaker. Make sure the wire has not been cut, or pulled apart. Both A and B come from the same part of the amp along with center. The rear channels come from a seperate board. Rotate the switch and see if you hear the sound of the relays falling in the back.
Aug 31, 2010 | Sony STR-DE497 Receiver
Center speaker cuts out.
Nov 15, 2008 | Sony STR-DE675 Receiver
Hi There,
Nik
Aug 01, 2008 | Sony STR-DE505 Receiver
Center speaker
mine is doing the same thing, you can hear a click sound and the channel will die. I think it is a relay or a shunt that trips when something goes wrong with that amp. I dont think it is worth repairing as there are some nice receivers out there for cheap. Maybe just a cold solder joint somewhere? Anyone know where and Ill dive in and resolder and post the results.
Feb 24, 2008 | Sony STR-DE545 Receiver
Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Jan 07, 2007 | Sony STR-DE945 Receiver
Speaker Off/On
If I am reading your symptoms correctly, it sounds like you are getting audio to your surround sound receiver, but not your TV speakers? If that is the case, I would be checking for a defective audio output IC and possibly an IC Protector fuse connected to it.
Dec 29, 2006 | Sony KP-53V75 53" Rear Projection...
Sony STR-DE1075 Receiver Logo
81 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
