Question about Mitsubishi VS-60609 60" Rear Projection Television
No power to tv
When I power on the TV the green light appears for about 3 seconds.  During this time there is no sound and no image on or from the tv.  After the 3 seconds the power light goes off.
Any suggestions?
    Genius:
  • 1,139 Answers
Hello Olsol,
This is an indication of a problem in the power supply. This problem can be in the switching power supply or in the high voltage power supply in either case there is some overcurrent or overvoltage condition which is cuasing the issue. Look for blown fuses and replace them, once this is done power on the set. If this works then great, but if not look at what is happening prior to the fuse blowing. Then using the schematic and a voltmeter attempt to find the shorted or open components by the lack of proper voltage readings. However if you do not have a background in electronics, I would suggest that call a TV repair shop and have this TV repaired.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 18, 2007
Sony fd trinitron colour television kv 29ls60e
The power supply probably is failing.
Jan 10, 2014 | Televison & Video
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Power on green light but no display. Display appears only for merely 3 seconds. Pls help.
If you get sound from the TV it's likely your inverter board that needs to be replaced. Unfortunately you did not provide enough details to give you further help. Next time maybe post TV brand/Model# and more details about the problem.
Best!
Jul 05, 2010 | Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Double image on letters for progran guide, 12" green line during perfect focus and on start up componet one need to be re-booted a few times to acquire video
Best advice run as fast as you can to the nearest Repair Shop that does samsung warranty- /// quit calling circuit city it seems like they could care less if your set is fixed or not bad business,first of all those double images you are seeing means you have convergence going out repair cost with out warranty is 350.00 and up to as much as 560.00
Jan 19, 2008 | Samsung HCN529W 52" Rear Projection...
WHY WONT IT COME ON?!?!?!?
If you would like us to help you, you must tell us what brand and model TV you have.
Aug 28, 2007 | Televison & Video
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-60609 60" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
