Question about JVC LT-42X688 46 in. LCD HDTV
Jvc-22dg52j no sound on analogue stations - JVC LT-42X688 46 in. LCD HDTV
Just got digital service, can't tune the stations
Check and make sure that your TV has compatibility tuner [analogue / Digital] provided inside. If not, you have to buy a digital to analogue converter to receive digital transmission. Refer the device user manual for details. If f the tuner is digital/analogue compatible; and you can't receive digital channels, it is faulty. The tuner have to be replaced. http://electronicshelponline.blogspot.com/
Dec 06, 2015 | Televison & Video
Hi my pro-82 will not pick up digital stations ??
You have a analogue tuner so you can only pick up analogue stations.
Oct 18, 2015 | Radio Communications
Why no sound?
no mention of cables used . Could be analogue cables in ps4 on analogue output . Digital output would have a digital output port using digital cabling I would deduct on ps4..
May 20, 2015 | JVC Audio Players & Recorders
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
Analogue receiver loses preset stations frequently.
I would guess that their could be an internal battery, like the ones in digital watches, that feeds a memory chip. There's another possibilty that the feed to the chip is a memory retention capacitor. If so look for something like this on the PC Board. They are always 5.5 volts if that helps.
Mar 31, 2010 | Audio Players & Recorders
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
How do I know where to attach the cables to upload
since it's an analogue camera and using a standard tape format, you might as well purchase a VHS-C adapter cassette (GB£10 from several photography stores) and run through your VHS VCR into an analogue video capture card.
Jul 16, 2009 | JVC Video Cameras
Digital TV Stations
The term digital in this case is the mechanism used to tune in stations. Rather than making adjustments using a front dial to fine tune the stations, there are digital circuits that will lock in the station. The "digital" stations you are referring to now are the over-air digital broadcasts what use a different method for transfering the signals over the air. These stations now broadcast a digital stream of information rather than an analogue TV signal. If you are using an antenna for receiving these over-air broadcasts, you will require a converter.
Dan
Sep 18, 2008 | Disney 13" TV
JVC LT-42X688 46 in. LCD HDTV Logo
50 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
