Question about Ferrari Vehicle Parts & Accessories
Hand brake system - Ferrari Vehicle Parts & Accessories
  • 91 Answers
Do you need to know how it works? what Ferrari are we talking about, whats wrong with handbrake, more information required?
Posted on Jan 25, 2015
1.9vauxhall vectra C fitted new pads and hand brake cable now handbrake has too much travel same as before items were fitted
it looks like a common flaw in design
it can fail an mot if handbrake wont hold
with both wheel of the ground and hand brake fully applied do the wheels spin
handbrake cable system on a
1.9vauxhall vectra C says self adjusting
but this picture implys there is an adjustment point
source
Thread Handbrake adjust
you tube vectra handbrake system in action
Opel vectra handbreak
Jun 15, 2016 | Cars & Trucks
How to repair rear brakes on Renault Kangoo Van
I thought Kangaroos walked on 2 legs.
ask your brake man?
FOOT main rear brakes or the rear hand emergancy brake.?
he :(both)
1: looks at them for wear and leaks.
2: Replace pads and shoes and all the parts that he SEES are bad.
3: adjusts them per FSM.
4:and road tests. it.
Jun 30, 2014 | Cars & Trucks
HAND BRAKE AJUSTMENT for Kia Picanto can notadjust the hand brake and how do I get at the hand brake tensioner
Brakes are self adjusting whether disc or drum.
I'm guessing the fault is lack of servicing of the brakes. You shouldn't have to alter the cable adjustment to offset a brake system in poor repair. Get the brakes cleaned and correctly set and you should find the handbrake sets itself. Check the cables release properly and move freely to allow self setting to occur.
Nov 05, 2013 | Cars & Trucks
2006 Tacoma faulty Brake indicator light
Please note that the hand brake is NOT the only reason that this light will remain on. It is possible that the light is trying to warn you of an hydraulic failure in your brake system.
Check your brake fluid level to make sure the fluid level is not low. If you find that it IS low, you need to investigate to find out WHY it is low. You shoud never have to add fluid to your brake system reservoir. If it is low, there is a reason for it that needs to be repaired.
If the fluid level is not low and you are certain that the hand brake is fully released, then you could have a bad hand brake switch, a defective fluid level sensor, or shorted/damaged wiring.
Oct 23, 2011 | 2006 Toyota Tacoma
Hand brake warning light stays on
THat is not only your hand brake warning light but that is also the warning light for your brake system. IF you are not capable of servicing your braking system get it looked at by a service center right away this is not something that you want to take chances with. Check your brake fluid in the reservoir to start and if it is empty add some and make sure that it is not leaking out!
Mar 20, 2011 | 2005 Jaguar S-Type
96 Corsica hand brake warning light stays on
along with warning that the e-brake is engaged, it's also a waning light that something is wrong with the brake system. however, it may be a defective switch on the e-brake handle. i would have a break check done. also chech the fluid level.
Mar 22, 2010 | 1996 Chevrolet Corsica
Focus, esp is not working and the abs and hand brake lights on
Either the system needs servicing or something has gone wrong with the brake system (YOU STILL HAVE REGULAR BRAKE OPERATION THOUGH). Check brake fluid, fuses, and try disconnecting the battery and leaving it for about a half hour. Hope this helps.
Jul 08, 2009 | 2000 Ford Focus
Alpine IXA-W404 how do i can't get video to play. I didn't connect the hand brake wire and the footbrake wire, would that be the cause and if so how do I get past it??
You need to connect the yellow/black wire to the brake switch and the yellow/blue wire to the ground wire on the hand brake. After that you have to go through the task of holding down the foot brake, pull the hand brake, release the hand brake, pull the hand brand then release the foot brake.
after all that then you can watch your video. You will want to connect those wires so you can setup your system.
Jun 07, 2009 | Alpine Car Audio & Video
Renault scenic flashing warning light on right of display bottom row right hand corner. i do not have a manuel so can you tell me what this means? looks like a circle with a line in.
check your brake fluid level( as this light is the hand brake warning light) but if it comes on with the hand brake in off position and ignition on it warning low fluid level in the braking system
May 16, 2009 | 2001 Renault Sportwagon
Hand brake does not pump brake fluid to rear disk pads.
The hand brake is not designed to pump brake fluid to the rear pads. The hand brake/emergency brake is a cable driven system with shoes in the drum that is the center of the rotor. Please do us all a favor and take your car to a reliable mechanic.
Aug 07, 2008 | 2005 Subaru Outback
Vehicle Parts & Accessories Logo
Top Ferrari Vehicle Parts & Accessories Experts
Roger Bourchier
Level 1 Expert
Paul Nielson
Paul Nielson
Are you a Ferrari Vehicle Part and Accessory Expert? Answer questions, earn points and help others
