I'm getting an I/0 error and my DVD/CD player does not work when I investigated it said it was a Code 10...Vista
  • ikkenom May 11, 2010
    Have you tried the DVD disk in some other DVD-player?
    If it fails, then the disk, not your DVD-player, is "bad".
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Turn off the machine and the unseat and reseat the cables to the dvd drive. Then turn on the computer and go into your BIOS and check to be sure that the dvd drive is recognized. If it is then reboot into windows and see if it reads discs.
  • 30 Answers
If you turn off the computer and remove the ribbon cable to the DVD play then at both ends the reinstall it. This works in some cases the error code you have means it cant read the IDE
Posted on May 18, 2009
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
My Matshita dvd ram uj 857s says code 10. I have
It's not "regeit" but "regedit".
Drives Disappear After You Install ITunes or Norton Ghost** If after installing ITunes or Norton Ghost, you get Device Manager error code, try locating the Audio File System (AFS) driver from Oak Technologies at C:\Windows\System32\Drivers\afs.sys or doing a search for it. Rename it afs.sys.txt and reboot. This driver is incompatible with the driver found in iTunes and Norton Ghost. The driver from these two companies is the same and made by a third company called Gear Software. After renaming the afs.sys driver file you will lose access to the CD burning feature of of the following: HP Memories Disc Creator, Liquid Audio Portal Player, Oak Technology SimpliCD, or Broderbund's Print Shop version 20. If you still wish to use the burning feature in any of that software, upgrade it to a Vista versions. For more information, see the article here - http://www.gearsoftware.com/wiki/index.php?title=CD/DVD_drives_disappear_after_installing_iTunes.
Description of Code 10-related errors that Device Manager generates in Windows-based computers
http://support.microsoft.com/kb/943104/
Please do all the below even if you have done some before as it is often the total process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
Then work your way through these - remember the drive could be bad, could have a loose cable or
slight corrosion on the contacts (usually for a laptop) and other issues.
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/314060 - a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Dec 30, 2009 | Dell XPS M1330 Notebook
CODE 10 ERROR
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Mar 30, 2009 | Samsung Super-WriteMaster SH-S183L Burner
Dvd rOM BURNER HAS ERRORS
Try a new DVD ROM. They are very inexpensive.
Mar 23, 2017 | Computers & Internet
DVD cd player not working
HL-DT-ST DVDRAM GSA-T20LATA Device the dvd player not working
Jan 12, 2009 | Computers & Internet
Vista Ultimate disabled my Blu Ray DVD Player
How to fix Code 39 error
with DVD/CD-ROM drives in Windows XP or Vista
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
6) After deleting the keys, close the Registry Editor
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Another possible CD/DVD issue you may want to investigate
http://www.pchell.com/support/copytocd.shtml
Microsoft surprised more than a few people on Thursday when one of its developers told a technical crowd in Australia that 32-bit versions of Windows Vista won't be able to play back next-generation high-definition protected content, i.e. commercial Blu-ray and HD DVD discs.
Later Thursday, representatives in the U.S. said that senior program manager Steve Riley was mistaken.
"The information he provided to that audience was incorrect," a representative told CNET News.com. "Playback is possible with Windows Vista in 32-bit."
The decision of whether to offer that support, the representative said, won't be made by Microsoft but rather by the third-party software makers that create DVD playback software, folks like CyberLink and InterVideo.
"It is up to the ISVs providing playback solutions to determine whether the intended playback environment, including environments with a 32-bit CPU, meets the performance requirements to allow high-definition playback while supporting the guidelines set forth by the content owners," Microsoft PR manager Adam Anderson said in a statement. "No version of Windows Vista will make a determination as to whether any given piece of content should play back or not."
Oct 02, 2008 | Microsoft Windows Vista Ultimate Edition
TEAC DV W28ECT ATA DEVICE CODE 10
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Aug 24, 2008 | Teac CD-Rewritable W28E CD-RW Burner
LG GSA.4040B doesn't recognize DVD's anymore , only CDs working
sounds simple
in the world the cd dvd creaters are using a new format of cd dvd making old players obsolite due to piracy these new cd dvds are becoming a pain a way they make you go out and purchase new players with updated formats
i found this out a few months ago when i bought a dvd from store it wouldnt work in a 7 month old dvd player so i got to thinking about it put in older cd that worked did a little investigating i want to know why new cd dvds werent working low and behold i found a tech site for the cd dvd compile build formats there it was piracy is getting knocked out by new cd dvd format this is so you cant copy direct to or from disks
if your older disks worked in drive and older disks burned in drive 9 out of 10 the problem lies with in new disks and what i explained up top
i hope this help you in your quest
Jun 02, 2008 | LG GSA 4040B (GSA-4040BI) DVD±RW...
LG ht752 codes
THERE IS NO HANDSET CODE JUST SOME DATA ON A DISC THAT ENABLES IT.
IT WILL NOT CHANGE THE FIRMWARE OF THE PLAYER OR BRICK IT IN ANY WAY OR INVALIDATE THE WARRANTY!
The place to get it from is here http://www.lgregionfree.mfbiz.com/#/instructions/4525089618
You need proper CD burning software like nero as windows xp/vista wont copy it correctly.
Basically you download the zip file from the site. Unzip it and place its contents onto a cd.
(On nero make it a data disc)
Stickitinto the drive when it loads the disc should eject and you shouldhave a screen giving you the current region and asks what region youwant to make it. Make it 0 for multi-region.
Just done this today thats how i know making a cd on vista/xp doesn't work.
Mar 13, 2008 | iLO DVD Recorder DVDR05
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
