Question about DeLonghi Nespresso EN660 Espresso Machine
Milk jhar problem flothing not propar
Flothing not propar
Which kind of plant-based milk is best to make cappuccino?
One can use many types of plant based milk for making cappuccino. It can be soy milk, almond milk, coconut milk, chia milk, hemp milk, rice milk, oatmeal milk, hazelnut milk or any other.
According to my taste, I always use almond milk to make a cappuccino as it provide a great taste and flavour to the cappuccino.
Jul 03, 2013 | Wine & Spirits
Tip
Raw Milk Vs Pasteurized Milk Nutritious Comparison, Facts, Advantages &...
If we are drinking pasteurized milk then we at least have to know what does this mean and we are avoiding raw milk then we really need to know why it should be avoid. Here today, in other way, out of syllabus topic is going to discuss but its more important and very close to life topic and most controversy one, is researched and published in simple and sophisticated way.
We know milk and its products provide higher nutrition benefits but the question is do we really know which kind of milk it is?? There are reasons to prefer raw milk but there are much more reasons to go with pasteurized milk. Are you believing that the raw milk is better for you than pasteurized milk then check out this simple and quick hypothesis to find out the answers about raw milk vs pasteurized milk.
Differences between Raw Milk and Pasteurized Milk
Comparison between raw milk Vs pasteurized milk is carried out in simple manner and quick research produced just to elaborate to everyone easily without going in much technical details.
No. Raw Milk Pasteurized Milk
1. This milk is the direct milk from animals like, cow, sheep & goat. Process: Pasteurization [developed by Louis Pasteur in 1864] is a heat treatment which obtained by keeping the milk at a specific temperature of 145F to 150F - High Temp/Short Time [H.T.S.T.] for half an hour, at least, and then decreasing the temperature to not more than 55F. In simple words; it is the process of destruction of certain germs and the prevention of souring milk.
2. This milk is directly served. This raw, unpasteurized milk can carry dangerous bacteria which are responsible for causing numerous food-borne illnesses. Milk is pasteurized to kill harmful bacteria before it served. On high temperature, harmful bacteria are removed by 99.99%.
for more read full topic here:
Raw Milk Vs Pasteurized Milk Nutritious Comparison Facts Advantages...
on Sep 20, 2014 | Health & Beauty
What is plant-based milk?
Plant based milk is produced through plants and is a non diary milk. Some examples of Plant based milk are almond milk, soy milk, rice milk and oat milk.
These milk very widely in macronutrient and micronutrients composition.
How does soy milk compare to whole milk as far as nutrition goes?
Let's take a look at the different nutritional values of soy milk compared to whole milk:
Calories- soy milk has fewer calories than whole milk per cup (about 40 calories less per cup).
Fat- soy milk contains 3.5 grams of fat per cup (8 oz.), while whole milk contains 8 grams of fat per cup (8 oz.)
Cholesterol- soy milk contains no cholesterol, while whole milk contains 24 mg cholesterol per cup.
Both soy milk and whole milk contain high amount of calcium per cup that provides about 30-35 percent of the RDA.
Protein- Soy milk has about 5 grams of protein per cup, while whole milk has 8 grams of protein per cup.
Feb 04, 2013 | Cooking
Whats the difference between skim and whole milk?
Skim milk is milk that contains no more than .5% fat by weight, while whole milk contains about 3.5 percent fat. This means that whole milk contains more calories than skim milk (almost half as much). Also, skim milk and whole milk taste differently because of the fat content. Most people prefer whole milk's taste because skim milk is too watery.
When I am connecting to pc it is work proparly but when i am connecting to my car audio system it can't open.and massage appear errer. please suggest me solution how can i open this pen drive in
check which all song format car sterio works and convert the files into that format using format factory (which is available free for downloading) and check it will work
Jul 10, 2012 | Electronics - Others
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi Nespresso EN660 Espresso Machine Logo
14 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
