Question about Creative Labs TravelSound 250 Computer Speakers
Creative travelsound 250 - Creative Labs TravelSound 250 Computer Speakers
How do you disassemble this? Needing to check to see if spring is broke! Its for a Polaris trailboss 250 1993 model
Here's a link for parts info
https://www.google.ca/#q=polaris+trail+boss+250+pull+start
Being the mechanical sort that I am I would start by removing it from the machine and then try to determine how to dis-mantle it.
Some of these were rivetted together so may require some creative technical abilities to re-build.
Checking with the nearest dealer is always a good option.
Dec 30, 2015 | ATVs
My speakers have stopped working.....there was an orange flashing light on the surround mode?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 28, 2011 | Creative Labs TravelSound 400 Computer...
Sofwere de instalacion
Hola!
Puedes descarlo desde aqu?, entre otros programas y utilidades (o use este link directo)...
Suerte y saludos desde Per?,
Pelu.
Apr 25, 2011 | Creative Labs Zen Micro MP3 Player
WHAT usb LEAD DO i NEED
You need a USB 2.0 Interface cable, such as this cable available on Amazon-
http://www.amazon.co.uk/gp/product/B000EOTDQ4?ie=UTF8&tag=microsift-21&linkCode=as2&camp=1634&creative=19450&creativeASIN=B000EOTDQ4
//javaftper
Jul 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I cannot open up the CREATIVE SBS250 casing to get inside of it, all screws removed. The plastic will NOT BUDGE. How do I get inside of it, short of taking a hammer to it? ;)
They are usually glued and screwed.
This is because they are intended to be replaced instead of serviced.
Therefore, a hammer is an excellent choice. A chisel may also be useful. Make sure you wear eye protection. ABS plastic is very stubborn.
I recommend www.newegg.com if you are in the market for computer parts and accessories.
Mar 11, 2010 | Creative Labs SBS 250 Computer Speakers
Necesito instalar mi wed cam pero no tengo el cd de instalacion el modelo de mi wed cam es creative labs inc vf-0050
Espanol: (English below)
Muchos sitios en línea tienen capacidad para detectar y buscar los controladores. Usted podría intentar una de ellas.
Sospecho que su cámara web ya no es soportado por Creative Labs.
Si la webcam es USB, puede ser capaz de salirse con la suya utilizando un software diferente. Usted podría intentar encontrar driver para VF-0450. O, incluso un competidor como el software Logitech QuickCam. Este último es utilizado por varias cámaras web.
Por último, una nueva cámara web puede ser la mejor respuesta. English: Many sites online have ability to detect and search for drivers. You could try one of those. I suspect your webcam is no longer supported by Creative Labs. If webcam is USB, you may be able to get away with using a different software. You could try finding driver for VF-0450. Or, even a competitor software like Logitech QuickCam. The latter is used by various webcams. Lastly, a newer webcam may be the better answer.
Oct 12, 2009 | Creative Labs Creative Webcam
Limited downloads on mp3 player
Probably because your songs are at a very high bitrate eg. 320 (CD quality) as opposed to 128 (average quality). Songs at a higher bitrate take up more space. So the Zen Stone can hold 250 songs at a bitrate of 128 but only, say, 150 at a bitrate of 320. Your solution would be to use http://www.dors.de/razorlame/index.php to decrease the quality of your mp3 & make the file size smaller.
Dec 17, 2008 | Creative Labs ZEN Stone MP3 Player
Spare
It is definitely NOT cost-effective to repair it. Ask your local Geek Squad if they are willing - probably no - minimum $250. If you live in Philadelphia or another major metro, see if they have Mp3 repair servicemen - most places do not because the actual builders/info is in Korean, Japanese, etc, and b/c it is less expensive to replace than to repair.
May 15, 2008 | Creative Labs ZEN V Plus MP3 Player
ZEN V plus
May 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Labs TravelSound 250 Computer Speakers Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
