Question about Denon AVR-682 Receiver
Reciever keeps shuting off.
Every time there is a loud sound on the TV it shuts off
0 characters
1 Points
Receiver suddenly turns off
If you have the vollume control set around 40, End watching a movie if there is a loud burst in vollume,It is causeing the reciever to run over it,s wattage rateing. End over heating,When it,s shuts down, It went into what is called the protection mode.Keep it at a lower vollume then it willnot do that.Allso what can cause it to do that, If you have your output leval control on your sub turn right up.
Oct 17, 2012 | Yamaha RX-V665 Receiver
I will be watching either satellite or movies through my PS3 and the sound will suddenly go out. I"ll get a loud humming sound or static coming through the speakers. After i shut off the reciever...
may be there was some loose contact in ur receivers rear connections.thts why it produce the loud hum. use good quality inter connects. check is the all connectors are properly inserted or not.
Dec 23, 2010 | Denon AVR-1508 Receiver
Onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Aug 08, 2009 | Onkyo TX-SR606 Receiver
Keeps shuting off
If the receiver shuts down after some time operating properly it is likely caused by a heat issue or crossed (shorted) speaker wires. Please make sure that the unit is adequately vented and the air vents/fan on the back of the receiver is clean. If it is then carefully check all of the speaker wires for cracks, damage, and/or crossed wires.
Feb 26, 2009 | Yamaha HTR-5630 Receiver
Technics receiver shuting down
check fuse on the inside of the stereo.
Nov 25, 2008 | Technics SA-DX930 Receiver
Shuts down at high volume
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Denon AVR-682 Receiver Logo
Top Denon Audio & Video Receivers Experts
Level 1 Expert
Tech Leprechaun
Tech Leprechaun
Are you a Denon Audio and Video Receiver Expert? Answer questions, earn points and help others
