Panasonic dmr eh59
We are streaming from a Mac mini computer, through a Panasonic DVD recorder (model no: DMR-EH59), onto a Samsung Smart TV. We hear and see the streaming picture & audio from the Mac mini with no difficulty but once we press record on the Panasonic, it records all visual but no audio
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a Samsung LCD TV (LA27T51B) and have just
Hi.
The possible connections that you can use are :
  1. AV cables- three cables -yellow video/red+white audio
  2. Component cables - 5 cables - three red green blue video / red+white audio
  3. DVI - DVI connector/red+white audio
  4. VGA no audio
You may need to buy some cable. If you are not using the computer, do not use DVI.
Possibly use the component cable, if not available on DVD use AV cables.
Here spare cables in Au$:
RGB Component Cable 3 RCA to 3 RCA
RCA Cable, AV Cable
Typing solutions take time,. if this comment helped, please do not forget to accept.
Thanks.
Ginko.
Posted on Sep 13, 2010
AJIN G
  • 6694 Answers
SOURCE: Can someone please tell me how to make a Panasonic
hi,
To make your player region free you need One for all universal remote ("ONE FOR ALL" URC-3450 REMOTE). First of all you have to programm the Onefor all remote for this purpose of king you player region free. Leave the DVD/HDD-Recorder switched OFF.
Procedure for Programming the remote. (you have to set the remote for your device)
A. Press the DVD button on the remote control
B. Peess and hold the MGIC bitton until the red ON /OFF button bliks twice.
C. Noe enter the device code for you DVD "0490". The ON OFF button will blinks twice.
Bellow are the codes to be programmed on the Numarical buttons 1-0 on the URC
numerical button Code
1..........................................00191
2..........................................00120
3..........................................00065
4..........................................00180
5..........................................00143
6..........................................00155
7..........................................00122
8..........................................00117
9..........................................00129
0..........................................00123
Now you can start programming the rmote.
1. Hold MAGIC button until the ON/OFF button blinks twice
2. Press 994 ON/OFF blinks twice
3. Press MAGIC button
4. Enter 5 digit code from above (00191)
5. Press button 1 (2,3,4-0 to follow) on remote ON/OFF button blinks twice
6. Repeat steps 1 to 5 for the remaining codes
programming of the rmote is over now Switch on the DVD player with no disc inside. Press the buttons on the one for all URC in the followin sequence. 1,2,3,4,5,6,7,8,9,0
The player will display HELLO
Now the player is region free
ok
Posted on Aug 08, 2011
gopakumarg43
  • 75178 Answers
SOURCE: no read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Posted on Apr 30, 2012
  • 19 Answers
SOURCE: Dvd recorder problems
On older models when a disk is inserted there is normally a sensor that detects a disk is in the drive, you have to start there. , sorry I can't be of anymore help
Posted on May 22, 2013
How to connect Panasonic DVD/VCR with Samsung Smart TV?
Connect the L. audio, R. audio, and video outputs to corresponding inputs on the rear of the TV.
Oct 06, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to set the time on dmr eh59
Automatic clock setting is done if you initially accept to use the guide plus system (should do). Only if for some reason it does not work, you can set the clock manually following these steps Clock Usually, the unit's setup function automatically adjusts the
clock to correct time. Under some reception conditions, however,
the unit cannot set the clock automatically.
In this case, follow the operation steps below to manually set the clock.
1 Press [3, 4] to select "Off" of "Automatic" and press
[OK].
2 Press [2, 1] to select the item you want to change.
The items change as follows:
Hour,Minute,Second,Day,Month.Year
3 Press [3, 4] to change the setting.
You can also use the numbered buttons for setting.
4 Press [OK] when you have finished the settings.
The clock starts.
If a TV station transmits a time setting signal, and when
"Automatic" in the Clock setting menu is set to "On", the automatic
time correction function checks the time and if necessary it is
adjusted several times every day.
Sep 25, 2012 | Panasonic DMR-EH59 250GB Multi Zone Region...
I have inserted a DVD-RW and nothing happens. I have to format it in order to use it in a Panasonic DMR-EH59. No clue how to do it. It's not showing on my computer.
If it doesn't show up on the desktop, open disk utility (applications > utilities). You should see an icon that looks like a CD on the left. Click on it and you should see a screen like below. Click on erase and it will format it. Be careful you don't accidentally erase any other drive.
Mar 01, 2011 | Apple Mac OS 10 (M7686LL/A) for Mac
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    PANASONIC DMR EZ47 WONT FINALISE
    NEED DMR-EZ47 - 475 DVD Recorder RRT Firmware Update
    Version RRT
  • Compatible Models DMR-EZ47VK, DMR-EZ475VK
    1. Enables the DVD Recorder to download the new V-Chip Regional Rating Table Data Stream.
  • icon-download.gifDownload
    http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EZ47VK.D#ts
  • Sep 14, 2009 | Panasonic (DMR-ES45VS)
    Panasonic dmr es15 dvd recorder
    My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
    using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
    Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
    Please help me with the set up of two Panasonic DVD recorders
    To record and veiw DVD movie at the same time connect the DMRE55 RCA cable output to DMREZ25 input 1 then the DMREZ output to yout TV input. Then on the DMREZ press input select and select IN1 to record from the E55.
    Nov 04, 2007 | Panasonic DMR-E55 DVD Recorder
    Recording a TV program on a Panasonic DVD Player/Recorder
    DMR ES 10 does not record on R + disc . change to R - disc and try
    Oct 03, 2007 | Panasonic DMR-ES10 DVD Recorder
    Televison & Video Logo
    Top Televison & Video Experts
