Question about Kenmore 98702 Stacked Washer/Dryer
No Heat on Kenmore Gas Dryer Model 417
I have a Kenmore Gas Dryer Model 417, but has no heat. I saw the heat element turn-on then off, but the gas is not kick-in.
Switch set for High Heat, Air flow is good.
please help and if need part, then what's the part number.
I suspect the device which switch the gas is bad. If so, how I can change this device. I have to peek on the back of the dryer and see the heat element, but I can't to this area. This is locate din the front of dryer, but I can't see the bult to open on the front. Please Help !!!
Thank You very much
    President:
  • 1,136 Answers
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further, please let me know.
Thanks
Vic
Posted on May 18, 2009
My kenmore (model 96573230) will not heat even after replacing heating element
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Kenmore 62602 Electric Dryer
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
I hava Kenmore Dryer model 417 and it spins fine. But the heating element doesnt work at all. This just happened after I jhad To replace my washer. These units were stacked. So maybe something is looose?...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 03, 2010 | Dryers
Kenmore Dryer 65512 won't heat
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
No Heat flown
there are a couuple of problems that would cause this.heating element bad or the hi limit thermostat has gone bad this is the most common failure.if you nees assitance and can look at the machine call me and it can tell you what to check 417-551-4311
Sep 16, 2009 | Kenmore 73952 Gas Dryer
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
554 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
