Indesit iwd7145 F12
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
F12 error code
Dado
Jan 23, 2014 | Ariston Technologies AWD121WH
Indesit iwd7145
no...its hards,,,,if you dont have any idea for repair,,,pls dont try
call the technician for your safety and not to waste money
Oct 31, 2013 | Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
My iwd7145 washing machine is flashing "h20" during it's washing cycle. What is wrong?
It means there is a problem with the incoming water supply.
Check water supply and water pressure, check hose/s for restrictions or kinks.
Check filter on inlet valve where the hose connects to.
Jan 16, 2011 | Indesit Washing Machines
Indesit wixe167 error code f12 what can i do? i check everything but nothing working.pls help me!
F12 indicates a communication problem between boards.
Carefully check connections and wiring bertween control modules.
Mar 01, 2010 | Washing Machines
Indesit wie 147 F-12
F12 indicates a communication error between boards.
Check all connections to the boards.
Jan 16, 2010 | Indesit Washing Machines
F12 code problem with indesit we16
F12 means no communicastion between boards.
Check all connections and wiring between the boards.
Good luck
Dec 14, 2009 | Washing Machines
CONTROL PANEL PROBLEMS WITH AN INDESIT
hi check all connections on the display module under top,and check connections on main module at the rear right hand side,f12 can indicate communication problems between the pcbs
Mar 05, 2009 | Indesit W 83
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
