Question about Emerson Humidifiers
MA-12010 comes on but will not stay on
When I attempt to turn on my humidifier, the humidity setting comes on, then the fan begins to move and then it immediately shuts off. Does not seem to matter which speed I attempt, nor what humidity setting I set it for. It is obviously getting power, as it does turn on. I've changed the filter and cleaned the unit. Has anyone else had a similar problem, and if so, can you tell me what I might try to get it working again?
    Problem Solver:
  • 5 Answers
My regservo need to active plz help me for activation code
Posted on Dec 29, 2013
SOURCE: Cool Mist Humidifier Filter Drying Out
Do you have tried to use without filter?
Posted on Jul 17, 2008
SOURCE: Drum does not turn
The rubber coupling is slipping. You may have a problem with the gear case; you can get a new one by calling Venta at (888) 333 8218. But it's possible that the rubber coupling is simply not seated properly. Snap the gear box out and make sure the socket is clean. When you put it back make sure that the coupling post is fully inserted in the drive socket. Hope this works for you ... Venta will supply new parts promptly if you decide you need them.
Posted on Dec 26, 2008
  • 3 Answers
SOURCE: Vicks humidifier v3850 isn't working
does anyone have a problem with a Venta humidifier not working proberly
Posted on Feb 27, 2009
  • 8 Answers
SOURCE: humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
Posted on Jul 03, 2009
SOURCE: Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Posted on Dec 16, 2010
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
Increased Humididity Setting ands now Water
Humidifier receives voltage when the indoor blower motor comes on in the heating mode, and blower motor dose not come on right away.See if water flows when indoor fan is blowing heat, Good luck.
Mar 04, 2010 | Honeywell HE225B Humidifier
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Looks like my humidistat calls for coil fan and for furnace heat
It sounds like the humidifier may be improperly wired.
It's hard to solve without checking the wiring, but it seems like the humidistat is wired so that as the dial is advanced, it incorrectly turns on the fan, or furnace, or both.  The contacts of the humidistat should be wired so that they turn on the solenoid only.  Also, the power to the humidistat, to turn on the solenoid, should come on only when the fan is on.
Hope this helps!
Jan 03, 2009 | Aprilaire 550 Humidifier
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Humidifier not collecting water
To both, these sound like de-humidifiers. Is your goal to reduce humidity and dry your room?
If so, if the humidity is low, then the de-humidifier has no work to do. A cheap battery or dial humidistat will help.
If not, check for a clogged filter. No air moving spells no de-humidification.
Also check for a frozen evaporator coil. Same as above but this requires repairs.
Electric dehumidifiers are similar to refrigerators and window AC's. With the fan running, adjust the setting to a lower humidity setting until you hear the compressor kick in. If it does not even at the lowest setting, check the space relative humidity to make sure it has work to do. If it does, repairs may be as simple as cleaning electric contacts in controls or as bad as a refrigerant leak or compressor failure. If its bad, better to replace.
A humidifier adds moisture. If you have a humidifier and want to keep the static off your clothes and keep your nose from drying out, fill the tanks with water and add biocide.
Please do not view my comments as patronizing. Even seasoned engineers have difficulty grasping humidification.
Sep 03, 2008 | Humidifiers
The fan blows but the humidified air stops after 2 seconds?
This is an old post, but you can make sure the humidity adjustment is full high. Perhaps it is defective or possibly, the environment is as humid as the high setting will allow.
Feb 08, 2007 | Bionaire BU4000-UC Humidifier
Doesn't humidify
hi first of all: disassemble the device to its basic components and clean them well - clean the filter of the device well: take it out, wash it well with hot water, dont squeeze it let it dry ... maybe the humidity gauge isnt working ... check it with antoher gauge good luck
Feb 22, 2006 | Honeywell HCM535 Humidifier
Humidifiers Logo
71 people viewed this question
Top Emerson Humidifiers Experts
Tom Chichester
Josh R
Are you an Emerson Humidifier Expert? Answer questions, earn points and help others
