Question about Ionic Pro TURBO Air Purifier
How to clean ionizing wire
My make a hissing noise when I turn it on and it don't stop
Ionizer wires get dirty
IT'S THE NATURE OF THE BEAST. IF YOU TRY A ANTI STATIC CLEANER THIS MAY HELP .. JAY THE POOL PUMP REPAIR GUY FLORIDA
Feb 03, 2012 | Honeywell Enviracaire Elite F300E-1019 Air...
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
How do I clean the ionizer when the check filter light turns on?
with no power to the unit take a soft moist cloth and wipe easy all the wires are flat plates
Apr 14, 2010 | Brookstone Ionizer/ Air Purifier Air...
Hissing noise from Ionic Breeze
The hissing noise is caused by the 5000-volt grid wires arcing. If you look inside the unit closely in the dark, you'll see blue electrical arcs -- these generate the hiss.
The arcing is caused by deteriorating grid wires. If you've cleaned it as well as you can, and it still hisses, it won't be long before it fails.
With Sharper Image out of business, don't know if there is still a repair service for these units.
Charlie
Aug 28, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red light and hissing noise
If, when you push the on button it sizzles for a sec and then shuts off (clean light goes on), I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Jun 08, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes...
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Oct 10, 2008 | Sharper Image Hybrid GP (SI724) Air...
Making sizzling noise
Unfortunately Sharper Image has discontinued support on the product line.  There was a recall going on with the product but since the company is chapter 11 right now, I don't think it is being honored right now.
What happened was Consumer Reports ran a test on ionizers, Sharper Image received a bad score and filed a lawsuit.  They lost the suit and had to pay all legal bills.
EPA has reported that using ionizers in a house or business may be harmful to your health.  You can read an article about it on their website.
The Consumer Products Safety Commission is going to release a final report on all ionizers by the end of the year.  Their decision may discontinue all sales of any ionizers in the United States.  This industry should have been regulated years ago just by the EPA data alone and for some reason it has been ignored.
Sep 10, 2008 | Sharper Image Professional Plus Ionic...
Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Jul 16, 2008 | Sharper Image Ionic Breeze® Quadra® 4.0...
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
Ionic Pro TURBO Air Purifier Logo
32 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
