Question about Garden
Onga pump diagram
When I plug in the pump the power trips straight away. I need a wiring diagram for an onga ltp1100E to see if I have wired the plug correctly i.e brown live, blue nutral and earth. hope someone can help. Thanks.
SOURCE: 24v wiring for RHEEM heat pump
Brown wire connect to com C on terminal block in your furnance (0VAC from 24VAC transformer)
Yellow turn on compresor (hot wire from 24VAC Transfrormer)
Blue switch Valve from AC to Heat (hot wire from 24VAC Transfrormer)
Purple prevent starting compressor in Heat pump and furnace in same time
Posted on Aug 28, 2009
  • 136 Answers
SOURCE: Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Posted on Sep 04, 2009
Testimonial: "Thanks that was GREAT!!!!"
  • 15340 Answers
SOURCE: Unplugged wires from a 89 Polaris trail boss
go to www.bikebandit.com and click for oem parts than go to polaris and year etc.. they have exploded diagramsof the machines from front end to electric system good luck
Posted on Sep 29, 2009
SOURCE: i have a little giant pe-a pump and need to know
hot=black
nutral=white
green=ground
unless you are rewiring plug end pump should be disgarded for safty sake
Posted on Nov 19, 2009
SOURCE: we have a pond pump that has a cut cord with
I just rewired a Beckett submersible with a new plug. Brown is hot, blue is neutral and green strip is ground.
Posted on Jul 01, 2010
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
Onga pump ppp750 plugged in will not start and no prime noise?
If needed, the owners manual for your pump is in the link below. This is a pump me for countries outside the USA. But if you are getting nothing, it is possible that it is miswired, or you have a failed pump-dead.
but by the wording of your question, it appears that it may have worked at one time, the way it is currently wired? If so, and nothing has changed with wiring, or any of the installation, then it is possible that if you hear nothing, either power has stopped going to it, or the pump motor died.
Check your breaker, any fuses, or wiring to the pump
and remember this one very important fact, to reset a toggle style breaker, you need to push it ALL The way to the off position, sometimes it is harder than you think, and then you can turn it to the on position. This resets a tripped breaker.
http://www.pentairpool.com.au/file/get/Pantera-Pool-Pump-Owners-.pdf
Mar 06, 2015 | Pool & Spa
Onga smh45 tripping rcd - about 20 ohms earth leakage - occassionally runs for about 10 secs -
Check the electrical connection for grounded wires or
loose electrical connections. Use wire nut for all electrical connnection and tape it properly. This should
correct the 20 ohms earth leakage. Send you e-mail comments for further assistance.;
Oct 19, 2009 | Plumbing
Have 88 f 150, turn the key and the pump in the gas tank has no noise. there are some pulled wires by the transfer case, broke by frame, that don't color code to anything. need a color code diagram of wire...
the nain fuel pump power on mos fords was PINK or RED. But 1st check would be the anti-rollover switch (Usually up near the kickpanel). If that has tripped, pressing the reset button will restore power to the pump.
Sep 11, 2009 | 1988 Ford F 150
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Fuel Pump Runs Continuously - Not Relay
It could be some water in a wiring harness plug causing the relay to stay on constantly, or a short to earth in the switching side of the fuel pump circuit, but really it needs a auto electrician to have a look over it to find out why the relay is staying powered on all the time. When you plug in the relay can you feel it click on straight away? Or does the pump run regardless of whether the relay is plugged in or not? If the latter is true, check for damage to the wiring loom from the relay to the pump. Other than that, its probably auto sparky time.
Hope this helps,
Mark.
Nov 02, 2008 | 1997 Ford Contour
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
