Question about Haier Refrigerators
Part number of starter compressor
Hello I have a fridge haier hrf-688ff / a fault: I hear a click near the compressor and after a few seconds again a click. I removed the starter and I noticed that it is cooked, in fact I can not read the model to be able to replace.The compressor is Embraco FGS100ha. Can you help me to understand the pattern of the starter? thanks and best wishes. :)
watugot
  • 290 Answers
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Posted on Dec 06, 2007
  • 833 Answers
SOURCE: Refrigerator buzzes & clicks
The only thing a capacitor does is 'kick' the compressor to start it. There is a box on the compressor containing the start relay. If it is defective or dirty, it might buzz. With the power off, find it, remove its cover and use some canned air to blow off any dirt inside. If that doesn't fix it, replace it. If there is a fan down there, be careful...and be sure it is working.
Posted on Dec 23, 2007
MNTECH
  • 1543 Answers
SOURCE: can't find compressor
The compressor is LG part number 2521C-A7256 which they have in stock. I believe this unit has a 7 year warranty on the parts of the sealed system (which includes the compressor) but this is most definitely not a do it yourself repair. Only someone certified to handle refrigerants, has the proper refrigerant recovery equipment, and charging equipment (and knows how to use them) should ever attempt to replace a compressor. Compressor failures are rare, and the unit should be diagnosed by a professional service technician, as most often your problem will not be the compressor, but some other issue. Please do not rate this solution as anything but a FixYa lowers my score.
Posted on Nov 30, 2008
SOURCE: Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Posted on Aug 26, 2009
SOURCE: Help w/ Refrigerator Compressor Overheating?
I had a similar problem yesterday (Maytag side by side unit 5 years old, however this apply to most brands). All operation seems normal other then that the refrigerator was not cooling, the air that was blowing inside the refrigerator was room temperature and not cold air. The compressor was also very hot to touch (could not touch it for more then 1-2 seconds) and didn't buzz or hum as in standard operation. I also heard few clicks from the compressor every time I plugged / unplugged the AC to the fridge. Replaced the overload/ relay device with a new one I got at a local appliance parts distributor ($30) and MAGIC. The unit went back to work as soon as I plugged the AC power. The relay/overload unit is on the side of the compressor and that?s where the electric wires are attached to. The unit turns the compressor on and off. The unit is attached to the compressor side with an "electric outlet" like three holes and three prongs. It might be held tight so you can pry gently (between the unit and the compressor body) with a screwdriver. Once pulled out, release the wires connectors that are attached to the relay/ overload unit. You might need to use pliers as they are tight fit. If unit smells like burnt or if you shake and hear rattle then it?s bad. Find a local appliance parts distributors and call to see if they have part for your model/ type. Remember to unplug AC before starting to work on the fridge and good luck.
Posted on Jan 15, 2010
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Defrost timer location
Check this out for manual: www.manualowl.com/p/Haier/HRF-588FR/Manual/99803
Feb 28, 2014 | Haier Refrigerators
Haier defrost timer location Refrigerators hrf-350
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Oct 13, 2013 | Haier HSW02C
Our side by side has lost its cool. The fridge section is luke warm while the freezer section is not working. We removed the started device that's plugged into the compressor, debris fell out, we...
Shut off the fridge for few hours and check the starter in the compressor which is having a fault. If your compressor is not running well then you will have to see if the starter is heating. If so replace the starter so that the compressor gets better current. You will need help to check the pressure of the gas and the pumping pressure of the compressor. The starter will click and start immediately to run the compressor. If the fridge does not cool the fault will be with the gas pressure or compressor. If not check your defrosting circuit, the timer and the thermostat. SO check this out. Good day
Aug 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Turns on hear a click shuts off
Bad thermostat is the most lilky cause,
Jun 20, 2010 | Haier Water Dispenser w Fridge...
Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Jun 02, 2009 | Haier HSP03WNA Compact Refrigerator
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
May 19, 2008 | Haier Refrigerators
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
