Question about Dryers
Kenmore charcoal-gas combo grill model #12216431010
I need replacement wheels but I don't have a complete model # or ?
SOURCE: Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Posted on Dec 11, 2008
  • 8 Answers
SOURCE: charcoal grill to propane
Shouldnt be a problem, the sell replacement kits for propane grills at most home improvement stores. Just buy the replacement kit and install it into your grill.
Posted on Feb 16, 2009
  • 37 Answers
SOURCE: Do I need lava rocks for my Kenmore 141.16322?
you dont need to have lava rock on it
Posted on May 05, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
bulldogchief
  • 388 Answers
SOURCE: I need 3 burners for Grand Gourmet Gas Grill Model No. GBC621A-M
Try this link: http://www.grillstuff.com/grill-parts/brinkmann/810-2300-b/?cat=27&brand=5&model=8938
It should bring you right to your specific grill and list replacement parts including burners.
Cheers!
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
Don't know how to use my propane, charcoal and fire box grill
Did it come with any sort of manual? That is probably the best way to start. If you haven't done it yet, hook up the propane tank to the hoses on the grill. I would say that the rack under the grill is for storing the propane tank and bags of charcoal or wood. Of course, the knobs are for turning the gas on and off. In between the left most knob and the one to it's right, there is an ignition switch type button, you press it when you have the gas turned on and with a lighter, you ignite the propane. Do NOT turn the gas all the way up before it is lit though, that is a sure way to burn some hair off or actually do some serious harm to yourself. In the charcoal section, you put maybe three inches of charcoal in the bottom of the cylinder. Use some paper or dry pine straw as extra fuel to get the charcoal started. Put a bit of lighter fluid on the charcoal then drop a match on it. I'm not too familiar with fire boxes, but from what I see, you need to use wood in the bottom of it. I can't see under the fire box, but you probably can dump the ashes out after you're finished with it. Start a fire with the wood and cook your food. If I may add a suggestion about cooking with wood, don't use nasty old rotten wood to do it. Cut some good smelling wood and let it sit for a while before you burn it. It will imbue the food with a good smell and taste. Other than that, it is up to you to learn to use your new grill. Good Luck.
Mar 30, 2013 | Grilling
I'm trying to locate a replacement coal grate (perferably in stainless steel) . Can you supply one? Thanks tlynch@inficon.com
Sorry, we don't sell anything on FixYa. However, if you get the dimensions of the grate you needand search around on Google for some the Grill Parts & Accessories sites and you're more than likely to find what you need. I will caution you, Stainless Steel Grates are expensive. Plus, they do not do well with charcoal. The charcoal gets so hot against, that it will pop and pit. It's not like doing it on a gas grill, where the heat is moist and the stainless retains it's integrity. Unlike coal or charcoal, which is an extremely dry heat. You may be better off with Cast Iron. Once it's seasoned, it should do better than Stainless Steel.
Hope this helped you. Please let me know. Thanks/
Jun 21, 2011 | Patio Classic 2000 Series Grill
Do I need briquettes for my weber silver grill
No, you don't use briquettes with a charcoal grill. Charcoal is slow to heat up any way, adding lava rock (briquettes) would make it even slower and hard to keep lit. However, its OK to add cooking wood chunks after the charcoal has heated up, to add a smokey flavor.
Happy Grilling!!
May 24, 2011 | Weber One Touch Silver Charcoal Grill
I was looking for the manual for the Char Broil "charcoal" grill, not the gas grill...
Unfortunately, the model number you listed is for a gas grill. There is not Char-Broil Charcoal Grill, that comes even close to that model number. If may have been discontinued. In any event, contact Char-Broil Customer Service 866-239-6777. If there's a manual available, the will email it to you.
Sorry for the confusion, but I based everything on the Model Number you provided.
May 11, 2011 | Char-Broil 461630208 Charcoal Grill
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
Charcoal in a gas grill...Wassup with that?
Well are they lava rocks or charcoal? The Master Flame series is supposed to have lava rocks. If what you see is charcoal, remove it and replace with the lava rocks. You can order the rocks from Char-Broil's website.
Sep 06, 2009 | Char-Broil CharBroil Master Flame Gas...
Regarding gas Barbeque and charcoal Barbeque
It depends on your preferance
Charcoal most say it gives what your cooking better flavor but the disadvantage is waiting for the coals to get hot and longer cooking time due to less heat.
Gas quick cooking time, quick warmup time the disadvantages scrafice some of the flavor, unless you buy a gas grill set up to smoke it is almost impossible to use a conventional gas grill for smoking, and also you have to have enough gas to cook completly or have a second tank in case you run out.
Hope this helps Ya
please rate me
Jul 20, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Dryers Logo
29 people viewed this question
Top Dryers Experts
